I had my doubts that a TD06 would have been a lil big. Thats why i wanted a 2nd opinion, so u think the below option would be better. It will be on a T3 flange manifold not a T25
http://www.ebay.com....#ht_2730wt_1396
If you can do T2 flange then I recommend the following, it actually works as an internal gate turbo (the T3 ones suck):
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Cover-TD05H-18G-T25-Flange-8cm-/280816756811?pt=AU_Car_Parts_Accessories&hash=item4161fba84b
Or if you are stuck running T3, get an external gate and hang a gate off the housing:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Anti-Surge-TD05H-18G-w-T3-8cm-V-Band-External-Gate-Hsg-/270902563574?pt=AU_Car_Parts_Accessories&hash=item3f130d12f6
Mate STATUS has posted a few results of people running the T67 on 98...
STATUS has posted results of people on 98 doing about 330kw, should be good for the same on others Id say.
If that the car I think you are talking about it has a T67 10cm (TRUST) and I'm pretty sure it has mild cams also ;)
Someone correct me if I'm wrong.
Edited by Wheezy
As others have said STATUS has posted various results between 300-330rwkw on BP98
STATUS is yet to disagree lol
He does a lot of Kando's.
So are there any more results of the T67 in pump fuel other than SimonR32?
Putting aside numbers for a second. Here is a 210rwkws Hypergear R33 GTS25t on good street/track tyres.(camera car). In fronf of him is an R33 GTS25t with a Trust T67-25G setup on RE55s. And in front of him me with my TD06-20G, I think i still had the std inlet plenum on at this stage.
So you have 210rwkws/street tyres chasing 310rwkws/semis chasing 260rwkws/semis. John in the camera car is a bit mad and with slightly quicker cars in front of him does a brilliant job of hunting us down, and murders us both under brakes...but you see the acceleration isnt worlds apart...and funniest thing of all...you dont see the T67-25G R33 get near my bumper let along overtake... :whistling:
I think this vid puts the numbers people sometimes chase into perspective. Would have been real interesting if the camera car had RE55s and had the same corner speed. But an extra 100rwkws means we do get away but we are hardly leaving him for dead.
yes that was a lovely rant Roy and you're right power is just a number, as you can only take a skyline around a corner so fast before the laws of physics take over and say no more...
While you point out that the car with more power isnt any better off, it definatly isnt any worse off either..
Now everybody head down the quarter,drifting,burnouts,dyno day,gymkhana and lets see who is the overall winner..cause there is more than one form of motorsport remember ;)
I only know one 'fast' :whistling:
Roy: rubber ones
Remember the old R33 is probably carrying 100+kgs on your R32 so the 50rwkw difference would be less significant :)
Yeh, not a 1000% conclusive anything video. I just thought it was interesting how such a wide range of engine outputs didn't really yield anything "fark me dead" different in way of how it got from one end of the straight to the other. I mean accelerating from 60km/h to 180km/h would be a pretty good test for acceleration. (My R32 is 1335kgs with no 5-10L of fuel and no driver :( )
And the only reason why I thought an R32 GTR rim would be a go for a run at Calder was I can get my hands on a pair and figure a 16x8 +30 is going to be better then my usual rims for fitting a drag style radial with a bigger sidewall...but fark it. Its all a wank, when I run again at the drags I will just run my old track tyres/ rims 17x9.5 so I am not scared of burning money with the burnout :pirate:
Your better off with a narrower rim for a drag radial, that way your tyre outlay is a little less and you get some more bulge on the tyre which will flex and give grip on launch. I dont need to tell you but the wider the rim the wider the tyre and up goes the price.
Personally the rims I have set asside for my drag adventures are a pair of Evo 4 Enkeis off my old E4 which are 16x6.5
Also, add 500ml displacement to your setup Roy and I think that video will look very different (not that I have seen it while at work)
yeah good old taxi wheels are probably easiest, 15 tyres be cheaper too..but there is plenty of lines running into the 10s on stock rims with 235/60s MTs (or were they 255s :unsure):.. I Got plenty of stockies here if u need em Roy...I dont think its all wank, wanking is what I did alot of before I had a car :laugh:
but f**k Roy in the same thread you are posting about wanting to dynotune 15 different turbos to log the slight differences in each u post a video/rant like this..so either you just wanted to brag that you were were winning or you are finding all that dynotuning hard to justify now? Either way, i dont blame you...lol
i havent watched the vid either yet,im sure it will be good.. .while they all might be as quick as each other on a track, its much more fun to just drop the clutch with twice as much power..but yes you can be just as competitive for alot less coin..
I often wish I had built my car more like John has and just got out there, but then again if all I wanted was a budget racer I could buy an MX5 and have just as much fun... But f**k that I have an engine capable of 500hp so why not have it...im not trying to win anything, i just do it for my own enjoyment..which ,now that i think about it, is alot like wanking :blink:
This guy is funny man.. :teehee:
Funny that the white R33 is the T67 10cm I mentioned earlier.... ;)
As said before, 98bp, T67 10cm, not 100% about cams.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
