But has it been setup to apply pressure to both sides of the diaphragm? It's unlikely but it's quick and easy to check, could have been overlooked?
thats how i set it up initially but the tuner said it wasn't needed.
i dont know if he changed it, jez asked me to check this as well.
i will find all out tomorrow.
okay i just spoke to my tuner and its getting vac from top port and side port (how i set it up initially)
he says it won't be the spring cause they can generally hold boost when set with a EBC/MBC to double their rated pressure (1 bar spring = 2bar boost on ebc/mbc)
im still gonna try Jez's gate with 20psi spring and see how it goes, if that fails, i will try his profec B 2 unit and hope for the best.
he still believe it has something to do with the mani or turbo as everything else "seems" to be ok, if it does fix the issue with either the above suggestions, i think its time i find a new tuner.
if this does not fix it, then i am at a lost and don't know what to do.
Perhaps the solenoid is stuck open a little? Try blowing through it. I seem to remember you need to swap ports on the solenoid too, to normally open.
I run a 1 bar spring using both wastegate ports, and run 30psi in the midrange but it still drops to 25psi by the top.
dont think this would be the case Simon, Blake (BSA) had the same manifold setup (but smaller gate) on his car and it wasn't an issue
what spring are you using in your gate at 1.5 bar ?
1 bar spring with Profec B Spec II doing the rest
Actually its sold lol, collected money for it yesterday.
Im confident theres nothing wrong with the disco itself but its a bad match to the high comp motor and the cams are also shit.
I did say you would make the 250-260 mark mate. A nice result, but like weve been discussing theres possibly more in it with another exhaust housing, probably not worth the hassle tho.
How responsive is it on the street?
i haven't really gave it much yet due to the shit rain but on the dyno its coming on boost 200rpm sooner than before
which was 4200rpm 19psi before now 4000rpm 20psi
not sure if its the eflex or cause i preloaded this turbo more where as the old td05 i had barely any preload on the actuator arm when i removed it
ive had 2 of these kandos now and both performed faultlessly and had no problems
first one i had on for 6 months on pump daily driven 1 track day and a few runs down the quarter and when i removed it was still like new these turbos are bang for buck and perform and good quality
Edited by hy_rpm
ok long story short , i bought another car to use as a track basher , it's a stock 32 pretty much , the turbo is touching the housing so it needs replacing . Digging through my shed i found a couple td05 trust turbo's i had bought a few months ago (td05h 16c in memory , off a gtr ) . Im wondering if this would be worth the effort of fitting up if I'm only aiming for 200rwk , it will be with a kando rear housing and cheap ebay external gate (and the usual mods obviously ) or should i just do the usual and whack a 25 turbo on?
I would do it every day of the week. And when you get bored of the 16g just whack on a kando CHRA.
Heres a shopping list for you champ:
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-TD05H-T517Z-T518Z-T3-8cm-AR61-V-Band-External-Gated-/290677531859?pt=AU_Car_Parts_Accessories&hash=item43adbb24d3
http://www.ebay.com.au/itm/TURBOSMART-ULTRA-GATE-38MM-BLUE-EXTERNAL-WASTEGATE-VL-/130653329019?pt=AU_Car_Parts_Accessories&hash=item1e6b8b967b
http://www.skylinesaustralia.com/forums/topic/391632-steam-pipe-single-turbo-manifolds-on-fleabayanyone-know-anythging-about-this-supplier-and-their-products/
unique automotive
i need a 0.5 or 0.6bar spring to test
after a bit of searching, i dont think the MVR springs work in the older WG44 gate, :\
Dori what springs you using, I think you may have it muddled up
here is the chart I have for my springs...
im running 3 springs in total,one .4bar and two .3bar springs gives me 1bar total
there is no .5 or .6 bar springs on the MVR only on the MVS
I dont think the blue spring is .6bar..that is the pressure of the green/blue combined...
not sure, but now im confuzzled too
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
