But has it been setup to apply pressure to both sides of the diaphragm? It's unlikely but it's quick and easy to check, could have been overlooked?
thats how i set it up initially but the tuner said it wasn't needed.
i dont know if he changed it, jez asked me to check this as well.
i will find all out tomorrow.
okay i just spoke to my tuner and its getting vac from top port and side port (how i set it up initially)
he says it won't be the spring cause they can generally hold boost when set with a EBC/MBC to double their rated pressure (1 bar spring = 2bar boost on ebc/mbc)
im still gonna try Jez's gate with 20psi spring and see how it goes, if that fails, i will try his profec B 2 unit and hope for the best.
he still believe it has something to do with the mani or turbo as everything else "seems" to be ok, if it does fix the issue with either the above suggestions, i think its time i find a new tuner.
if this does not fix it, then i am at a lost and don't know what to do.
Perhaps the solenoid is stuck open a little? Try blowing through it. I seem to remember you need to swap ports on the solenoid too, to normally open.
I run a 1 bar spring using both wastegate ports, and run 30psi in the midrange but it still drops to 25psi by the top.
dont think this would be the case Simon, Blake (BSA) had the same manifold setup (but smaller gate) on his car and it wasn't an issue
what spring are you using in your gate at 1.5 bar ?
1 bar spring with Profec B Spec II doing the rest
Actually its sold lol, collected money for it yesterday.
Im confident theres nothing wrong with the disco itself but its a bad match to the high comp motor and the cams are also shit.
I did say you would make the 250-260 mark mate. A nice result, but like weve been discussing theres possibly more in it with another exhaust housing, probably not worth the hassle tho.
How responsive is it on the street?
i haven't really gave it much yet due to the shit rain but on the dyno its coming on boost 200rpm sooner than before
which was 4200rpm 19psi before now 4000rpm 20psi
not sure if its the eflex or cause i preloaded this turbo more where as the old td05 i had barely any preload on the actuator arm when i removed it
ive had 2 of these kandos now and both performed faultlessly and had no problems
first one i had on for 6 months on pump daily driven 1 track day and a few runs down the quarter and when i removed it was still like new these turbos are bang for buck and perform and good quality
Edited by hy_rpm
ok long story short , i bought another car to use as a track basher , it's a stock 32 pretty much , the turbo is touching the housing so it needs replacing . Digging through my shed i found a couple td05 trust turbo's i had bought a few months ago (td05h 16c in memory , off a gtr ) . Im wondering if this would be worth the effort of fitting up if I'm only aiming for 200rwk , it will be with a kando rear housing and cheap ebay external gate (and the usual mods obviously ) or should i just do the usual and whack a 25 turbo on?
I would do it every day of the week. And when you get bored of the 16g just whack on a kando CHRA.
Heres a shopping list for you champ:
http://www.ebay.com.au/itm/Turbine-Housing-Kinugawa-TD05H-T517Z-T518Z-T3-8cm-AR61-V-Band-External-Gated-/290677531859?pt=AU_Car_Parts_Accessories&hash=item43adbb24d3
http://www.ebay.com.au/itm/TURBOSMART-ULTRA-GATE-38MM-BLUE-EXTERNAL-WASTEGATE-VL-/130653329019?pt=AU_Car_Parts_Accessories&hash=item1e6b8b967b
http://www.skylinesaustralia.com/forums/topic/391632-steam-pipe-single-turbo-manifolds-on-fleabayanyone-know-anythging-about-this-supplier-and-their-products/
unique automotive
i need a 0.5 or 0.6bar spring to test
after a bit of searching, i dont think the MVR springs work in the older WG44 gate, :\
Dori what springs you using, I think you may have it muddled up
here is the chart I have for my springs...
im running 3 springs in total,one .4bar and two .3bar springs gives me 1bar total
there is no .5 or .6 bar springs on the MVR only on the MVS
I dont think the blue spring is .6bar..that is the pressure of the green/blue combined...
not sure, but now im confuzzled too
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
