Hey guys, got a bit of an "oddball" setup going on, am doing a remote mount turbo. Engine is a VG30DE 10.5:1 comp, and am looking at a TD06-20G as the turbo. Will be running Water/methanol with no IC, but will only be running 7psi for the first week or two. Would a TD06-20G be too big? maybe choose a smaller exhaust housing then usual?
gday guys, thought id post my results from using one of these turbos
i have a tdo06 20g sl2 8cm rear on my rb20
turbosmart 40mm wastegate
550cc denso injectors
bosch 040 fuel pump
z32 afm
splitfire coilpacks
ebay spec front mount
3inch exhaust
Nisstune
still needs a little tweeking like a new CAS, decent front mount and cam gears are on there way.
cheers - trent
Hey mate, I dont think it would be too big. Possibly the smallest id run to be honest.
Yet I dont have any first hand experience with a remote mount, maybe it needs something different.
GL
bosch 040 fuel pump
z32 afm
splitfire coilpacks
3inch exhaust
Nisstune
cheers - trent
Wow plots so much different to mine, absolutely nothing happens till 4k then bang, it gains 120kw by 5k..must be fun :D
did you find out if that ring was missing in the gate??
yeah she up and boogies after 4k lol
im looking at jumping on the e85 bandwagon ;)
nuh it wasnt missing all good, is your dyno sheet in this thread mate?
edit; found it, very impressive mate :)
Edited by TJR32GTS-T
+1 more specs on the SR above please, and
JEZ: specs on the motor you recently tuned with the 20g internal gate please.
Its a stock rb25 Running stock manifold. Td06 20g 8cm 21psi on 98 octane pretty aggressive tune.
No vtc yet.
Has since made up a 5 bolt rear housing and boost pressure is safe and stable at 14psi. Should help with flow too.
Retune on 18psi once he gets car rego'd
This is a great turbo to stop getting defected coz it looks like a stock RB25DET turbo with all the japanese on it. Im also loving the fact that you can get about 300kw stock using this babe. Thumps up fellas for finding this masterpiece
8cm will be perfect for you, but if you're only running 7psi, you probably won't get much power and may be laggy.
what is your goal - response or outright power?
No vtc yet.
nice, i reckon it will be perfect streeter with response and 250-260~ rwkw and can match the similar turbo from hypergear.
i am here. :nyaanyaa:
should be getting the car back tomorrow so fingers crossed for no issues & good results...
Will be pushing it up to 15-17psi and yeah outright power is the goal.
go the 10cm.
the na compression will help spool it up
The below picture isnt a perfect example as the spreadsheet is the combination of my car on two different dynos and two different tuners. The dynos read about the same, if anything the dyno that produced the 8cm result read a little lower then the 10cm dyno. The tuner that did the 10cm tune was not as good a tuner as my current tuner. So that obscures the result.
But even so, I think it paints the correct picture as to what happens when you throw too big an exhaust housing on a car. Unless your car is choking on its exhaust gases, going to a larger A/R housing is a pretty risky way of trying to get more power. Especially with a turo mounted well away from the head. The exhaust gas would not have the same amount of energy after its gone through piping and cat/mufflers etc
If you want more power look to try and get your inlet temps as low as possible, back pressure from exhaust as low as possible, pressure drop in inlet as low as possible etc. Then have a look at your
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
