Car isnt even in the same state as me at present. All is ready to go, just need to get my car back as its currently getting some fabrication work done. I hope its going to be a bit of a weapon at Sandown in late April. Will be on E85 with the whatever proves the best performer. If its the billet then hopefully makes power at 26-28psi. On EVOs they seem to love the higher pressure ratios so the lil 20 will be earning her keep. Would be nice to make 320rwkws with the 73HTA or 250-260rwkws with the 18G
Well, I suppose I have Datalogit so will just buy 200L drums of E85 and run straight E85 at the circuit and throw 98 tune back in for getting around town. Pain in the ass, but everyone else is doing it so the lap times don't stack up without it :( The cars running it just have so much extra grunt for free, its not a level playing field running a full weight RB20 on 98 :(
Nobody has said anything here but United have 100 back. My car makes an easy 10-15rwkws more with it so tempted to run a 50:50 with 100 United / E85 to try and get some mileage out of the 200L of E85.
Kind of relevant to this thread...
This guy is using 2 x td06SL2 20Gs on his engine..
if you are interested....
it is a 1GZ-FE - 5L V12
Auto box
In to Gen 3 Subaru Liberty converted to RWD.
Build thread here..
http://www.performanceforums.com/forums/showthread.php?67274376-Cracka-s-white-boy-shitbox-Gen-3-Liberty.-TT-V6-wouldn-t-fit-so-now-V12.
First start up vids on page 19 (not all hooked up yet but still...)
enjoy.
Mick_O is getting remarkably good mileage out of E85.
I drive 320kms to / from site every week + daily drive of about 30kms. I dont want to be paying for E85 and trying to source it. Hell, I may go a 91 tune :)
And replace your blocked injectors every 10,000ks lol
Honestly most family of mine who do not listen to me about the perils of 91 end up coming to me asking why their car runs like a lawn mower. Its ALWAYS a blocked injector, no matter how new the car is.
Just sayin' :whistling:
Have been running the EL wagon on 91 for about 8 years now. Never had a problem with blocked injectors.
My economy on E85 is pretty close to what it used to be on 98 as i only go for a blast here and there in my car as its not a daily driver.. Last tank of juice i got 410km with the fuel light on at 400km. Was spewing last week though E85 was $1.33 a litre most ive ever paid!
Yeah, TBH ive never had a problem with 91 in a falcodore.
91s hit list has been mostly nissan, toyota and honda. Pulsars, Corollas, Tidas, Echos, Celicas, Civics, that sort of thing and yes I have fixed a lot of bad injectors as a result of 91.
Either way I classify 91 as piss and think anyone would have to be stupid to use it in anything. Your call.
yeah i noticed the united 100, but i tuned with bp98 as usual i think, actually I dunno cause the fuel had been in the tank for 3 or 4 months before the tune so whatever I filled up with last, might have been caltex :unsure:
And people say fuel goes off...:no: so the united 100 is good yeah..?
Yeh, my tunes are not that line ball so when United have 100 I go to my 100 tune and just run 98 on the street. But when I go to the track I make sure I am running 100. Keep in mind 8 out of 10 drives I dont hit more then 4-6psi as I drive to attract as little attention as possible :whistling:
^ thats awesome mate thanks for sharing, helps me decide if i want one on my SR :)
Can you divulge the specs of that motor? Is it heavily moded or internally stock etc? headwork and cams? Thanks,
Also great to hear your getting back on the dyno today dori! cant wait
SR is forged with 260 pro cams with solid lifters. But tiny front housing is restricting power.
gday guys, thought id post my results from using one of these turbos
i have a tdo06 20g sl2 8cm rear on my rb20
turbosmart 40mm wastegate
550cc denso injectors
bosch 040 fuel pump
z32 afm
splitfire coilpacks
ebay spec front mount
3inch exhaust
Nisstune
still needs a little tweeking like a new CAS, decent front mount and cam gears are on there way.
cheers - trent
How much boost pressure? Looks like around 1bar from the figure. The cas holding you back? And what exhaust manifold?
Just trying to gauge if one of these is a compariable replacement to the trust item.
Cheers.
Cheers. Engine bay needs work as I have never cleaned it up properly after the fire. Plus loads of other small jobs where I just dont have the time as I am always away with work. Like ripping the dash apart on the drive up to Sydney over Xmas because my phone charger stopped working. So I cracked the shits and ripped out the centre console :closedeyes: Farking old cars...if you try to keep them tidy it never ends :nyaanyaa:
Im not sure about that, i think its the same as their 3" cover but with a 2.4" neck.
Thanks for sharing btw :)
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
