1. the walbro pump ran on my old setup and that ran 18psi without any issues.
2. BSA ran the same manifold setup on his and it held 17 or 19psi.
1. thats good to hear, so test that its still got good consistent fuel pressure, especially under load on the dyno.
2. realistically that accounts for nothing. remember he made the adapter himself, so his could have been a few mm different to yours which could make all the difference. I also recall he had a different size WG tube, but am happy to be corrected. You should also note that he ran it on an RB20 with a completely different turbine housing and wheel, which changes everything.
Am still dubious.
Could even be the turbo! Or Artz' car has some sort of secret squirrel stuff done to it :rolleyes:
The rear housing has a nice clean path to the wastegate, plumbed in right at the nozzle of the turbo. Of course it will flow better. Its not magic nor a secret squirrel mod, just good design imo. :thumbsup:
Lol..you want secret squirrels talk to Roy..
every mod I have made is well documented in this forum, just depends how much you pay attention to my ramblings.
I think I know the reason it has worked so well, apart from Trent who I took it to on a trailer and he had it running and tuned in, under an hour, awesome stuff, :thumbsup:
And scottnm35 who always puts the extra effort into tuning my whack ideas into metal :cheers:
Im thinking he may have forgot to raise the map limit. When n u send me the tune file tonight ill have a look
Surely he would have noticed that? Gotta be really really worried if he didn't! :unsure: Noticed the boost plot was for the 1bar run though.
TBH, i wouldn't be suprised after the last issue with my "boost issue" which was just the EBC set incorrectly.
the boost plot is only for the 1bar run, but from what i saw, the 1.2 and 1.4 bar runs was just flat line like the 1bar, no issues there.
Sorry guys, my comment was another reference to dori34's posts over in the HG thread lol. Scott, I really should have got you to make me an intake pipe in exchange for...my remaining Sougi lol.
i hope it doesn't come to the manifold having to be replaced.
we'll see, i'm taking it to Jez's place next weekend
I would think taking that centre bit out of the manifold is a bad idea. because the turbo isn't centered you have 4 cylinders of pressure on one side pushing against 2 from the other makes for uneven flow pattern. If it turns out to be the culprit piss it off and get a hybrid topmoumt I'm dying to see how well it would work :P
Failing that my guess is you have fuel delivery issues, but it's just a guess..
If its an issue with the manifold i still have my stock one in the shed man, let me know how you go :thumbsup: Or you can go high mount and be hektic like me :laugh:
hey mate, the splitter/divider is still on the manifold, it hasn't been removed.
the hybrid NZ manifolds do look very good value for $$ spent.
i will hit u up if it does come to that, but i hope not.
the hybrid NZ manifolds do look very good value for $ spent.
Yes the splitter is still in the manifold, and then there is a gate tube which merges it before it gets to the turbo.
Need to consider that the gas that goes through the manifold would pressurize the gate tube and pose a restriction on its flow path to the turbo. If it was after the merge it would be a completely different story.
I'm sure that could be arranged but has Racepace done it already? What did it end up costing?
How many bottles do you have left? I think there's still 6 in my shed...
that sounds feasible.
well i will let Jez have a look and see if he can find anything abnormal, otherwise, the only thing left is the hardware.
will know by next weekend.
Only got 2 x S6000 bottles left lol. I'll be switching to Syn X 6000 after that or using up the rest of the M5000. I dunno, they've had my car for two days now and that was first on the list of items so they've probably done it already...they said $250-$450 depending on what's required to fab it. Hope it's at the lower end of the scale :/
You aren't using Unique automotive are you? Few of my mates had quite a bit of trouble with the tuner there and even ended up blowing a mates motor up while tuning it.
Looking at the graph, it would have nothing to do with the manifold/turbo or gate...
Something else is funky... I would be taking to someone else is that was the result
Yeah, its going to DVS JEZ next weekend :thumbsup:
Unique Automotive in Villawood, often mistaken for Unique Auto Sports in Seven Hills.
if it is the correct one in Villawood, care to share more info and your experience with him?
cheers
cheers
Yeah Unique automotive in villawood, he tuned my friends turbo excel, well tried to atleast. They told him to tune it on no more then 10psi, but he ended up incorrectly setting the boost controller to 18psi. Was also overheated on the dyno 3 times.
Edited by Super Drager
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
