I get my content woes/information down a short grape vine from the very top of CAMS hierarchy. Not that it changes anything, but like I've said before we all form our opinions somehow.
Not a good source for information imo. Too many kickbacks from the race fuel industry perhaps?
Trent has tuned countless times with Eflex and C16 with little difference in performance or safety. I know which one I would rather pay for in my daily...
My kando/kamak T67-25G 10cm finally turned up today after a few delays, Compressor housing hits rocker cover so RB20's will go on, weld V-band and wastegate off exhaust housing tomorrow.
RB25/30, fresh rebuild
stock rb30e piston & rod
stock RB20in RB25ex cams, No VCT
ebay stainless manifold
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Splitfires coilpacks
Nismo 750cc
Modified twin feed rail
Twin bosch 044 pumps
Surge Tank
E85/Eflex fuel
Previously GT3076R :yes:
Your probably not wrong, I wont go there for now. Hate 'he said she said's', especially on the net lol. V8s did end up going E85 though, but with the guaranteed content CSR shit.
I have heard reports that eflex is fairly consistent at the e70 mark.. But I just cant get past the fact its a varying content fuel. Like I said in the HG thread, I fully believe in it as long as its used with a content sensor.
Once it properly rolls out in NSW and is available everywhere I will honestly be buying a flex capable ecu and getting it tuned on that :)
Freddy plenum
80mm throttle
Tial 44mm MVR
Apexi Power FC
Nismo 750cc
Surge Tank
E85/Eflex fuel
INSANE
Hi guys
After a little help and thoughts on the set up Im thinking of changing to. Its an SR20DET in my 180sx currently running a 2871r 56trim .64exh with HKS step 2 264/264 cams and supporting mods, it makes 268 rwkw on 18psi tuned on E10 100oct.
Im looking at going to the Kinugawa TDO6SL2-20G T3 V band 8cm high mount with Tial 38mm external gate.
So a few Q's
Will this get me close to 300 rwkw on 18-20psi?
Should I look at the 10cm housing or stick with the 8cm?
Will the 38mm gate be big enough on an SR?
Im keen to keep full boost of 18-20psi around 4000rpm.
Thanks for any input.
Cheers
Edited by slippylotion
Found a cheap Evo turbo td05-16g I can get 2 for a catch can would these be any good on a 26
I have a twin td05 kit off a rb26 , in memory it made close to 400 rwk and ran a 10sec quarter , I'm about to put one on a rb20 , hoping to see 200rwk
Is there a difference in sizes between a T2 8cm housing and a T3 8cm housing?
I know obviously the T3 flange is bigger but does this also mean the total volume is also bigger. So is a T3 8cm sort of the equevilent of a T2 10cm?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
