I need to spend less time on SAU and more time tuning my drifter aye :)
Been flat out with work. As u all know customers come first before my own cars. Well unless theres a race meet on.
Use excuse that tuning the drifter is good advertising... Good advertising = More customers
Have to spend money to make money :)
Just tune it farken! :thumbsup:
This. Then stock up on a bolt on kit consisting of:
Kando
Tial 44
NZ manifold
Dump
Intake
Cooler pipe
Then customers can drop off their car and you can install the kit PLUS tune it. Start emailing Suppliers of those parts (and a boily) and organise a 10 batch buy at discounted rates, pass on some of the discount to your customers with KICK ASS labour charge and your off n racing!
GOLD
does anyone wanna buy a TD06 3" turbo front cover? lol
For potential buyers it is actually over $100 cheaper to buy the turbo in parts (cover/core/turbine housing) than it is to buy it complete.
I think there was a dude a few pages back showing his mates one with a 2.4" neck, I rekon he would want your 3".
You might save $100 but you then need to assemble and balance the turbo. So I would get a price on balancing it prior to buying it in peices.
Does that include oil/water lines?
what $100 for a balance..................the cores/wheels are already balanced
Edited by stocker
i think the surge cover will definitely fix my issue (at least i hope it will lol) :)
only time will tell.
They are right in saying keep it for now man, Lith did say the VCT could be your issue.
Remember changing the cam timing alters the motors effective VE, just like opening the throttle does. (makes the motor more efficient)
That being said different VE = different area of the graph at given RPM/boost.
CFM = L x RPM x VE x Pr
5660
So watch this..
2.5 x 4000 x 90 x 2.5 / 5660 = 397.5 CFM
Now look here (Ive picked 97% as a random number as an example):
2.5 x 4000 x 97 x 2.5 / 5660 = 428.45 CFM
= Higher CFM, meaning further to the right of the comp map. If that doesnt make sense, I did you a graph. Remember that the outermost limit of the map on the LEFT side is surge and the RIGHT side is heat (excessive heat).
Remember also, these are rough calculations.. The VE could be lower or the comp map could be a little mis represented.. Either way, a rough calculation shows the motor is pretty damn close to the surge line at 4000 rpm.
Now plot it yourself at 3700 RPM where you probably are hitting 20psi and watch it come even closer if not cross the line.
Balancing in the east must be cheap as chips then.
sorry mate the point here is the Kando chra's comes built and balanced. you then just buy the housings and lines.
i hope that clears it up for you
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
