that is very laggy imo
it looks like Roys RB20 graph with a few more pony's up top
waiting for results with NVCS working
edit - that sounded a little harsh, 300rwkws from an L2 is great, but full boost at 5000rpm is not lol
LOL, too many results with no VCT :(
Interesting to note that the RB25, even with its extra displacement and half a point of compression doesn't really spool the TD06-20G 10cm as well as an RB20 running an 8cm housing. Will be interesting the difference the VCT makes. Would love to see the engine tuned on 98 instead of corn fuel, but if you have access to E85 and car is tuned for it understand why you wouldn't bother with 98.
I don't expect tuning along with E85 can see the result go from 17psi at 4,500rpm to the 21 psi at 4,000rpm of my graph above?!?! Then again I dont know dyno tricks 101 so perhaps there is something different to how the cars were loaded/run on the dyno. But my thing with no EBC and a simple but effective bleed valve which was holes in a bit of fuel line to bleed pressure gave me 21psi at 4,000rpm. Seems both engines are making ~130rwkws at 4,000rpm so the turbo isnt working as hard as you would expect at 4,000rpm on the RB25.
The above graph was not on my tuners dyno, and it was a comparo against one of the tuners cars other setups so it is at least a fair comparison to the other curve which was an RB20 running a HKS GT-RS.
Maybe the 10cm housing it a tad too big for the 20G compressor as the curve seems to have the BIG turbo shape of still climbing at the rev limit vs the bell curve look I would have expected of a 20G on an RB25.
Found it finally
yeah it should get close, was told it had a new clutch..big words like heavy duty and ceramic were used...
looks like they were just that... words :/
I hate the screamer already, when it first cracked I thought WTF!!!...some more work for you Scotty..lol
Thin red line is my old turbo, I have lost a little down low but it doesnt really feel any slower ..power ramps up so much nicer..
It Did hit 276kw at one point, holds boost nice too
Im just happy I can drive it again and as long as I dont mash the pedal too hard the clutch holds up ok :D
so got a reply back from them on ebay:
It still works as there is high % of Inconel.
If there is smoke, and then you need to start take care of this issue.
Gonna push for a replacement cause im not really interested in putting a timebomb back on...
All suppliers will cover their backside first, regardless of if they will warranty the issue or not.
You should ask him if the turbo gave up next week would he replace it then? And if the motor injested parts of smashed turbine wheel will he also warranty that?
Just point out there is a reasonaby high risk and the cracks were not there from new. That means they will only continue to spread.
Having worked with the person before I know he will accept the warranty claim after you make a large enough fuss about it.
Yeh, between United and Caltex it will be pretty easy for me to run E85 now. I am still going to just use Datalogit to switch back to ULP for daily duties and making sure I dont have E85 just sitting around in the tank and lines when I am away with work etc.
So can someone start to explain the difference between Artz's RB5-20G result and DVS JEZ's? Surely VCT and tweaking a tune doesnt make 1,000rpm difference in response???? I ask because I have read that on some setups E85 can make a setup spool a little slower....have not seen any cases of it yet and wondering if its a factor in this case
Yup :thumbsup:
yeah I got no idea, i dont quite understand VCT well enough to know how much difference it should make but it does seem a bit too much..
Jez is also top mount, which usually will helps spool a little earlier doesnt it...
Yup :thumbsup:
Also Jez has top mount which i thought should help spool earlier..
You said that twice in the same post... You drunk? Lol.
I don't see how top mount would help response? Unless the manifold is a restriction, and as I was told in the other thread in no uncertain terms, the stock manifold is not a restriction at these sorts of power levels. So I can't see top mount being of any benefit performance wise.
Jez is fairly conservative when it comes to his tunes in general, leaving a big safety margin. I would say his is just not finished yet and is still in its build stages, once VCT is in and hes able to ramp boost on harder Im sure the results will reflect its completed state.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
