Sounds about right, what triggered me to say that was the statement that Kandos are 1/3rd of the price of comparable products and while they are cheaper they are most definitely not 1/3rd. After paying attention for a while I'd feel much more comfortable getting a genuine Borg Warner, Garrett, Precision or Turbonetics turbo and get something long time proven and supported for possibly slightly more outlay.
my decision is based on the item itself more than the price or customer service.
the L2 20g is a good balance for the little SR in my eyes, and I dont think I will get the drivability I want from the PT (5558).
Jez is tuning a SR w/5558 this week so im keen to see how that turns out........... but im doubtful it will show me what i want to see.
Just make sure everything is working mint before you go... I think Sean is going to kill me if another car with a Kinugawa turbo comes in for a tune half put together and not working properly.
Actually I need my car tuned as well, might try and blackmail him into doing mine next week
Of course, I wouldn't have booked it in otherwise. I can understand Seans frustration over that.
Is that just in general, or did he mention my car specifically?
He did my run-in tune without any major drama's. There were a couple of minor unforseeable issues, like the thermo's suddenly deciding they didn't want to switch on anymore, or my spark plugs crapping out even though they were relatively new platinums.
Only things that I have changed since he last saw it, are that the fans are being switched on via the ECU now, and boost controlled by a MAC valve via ECU (As per his suggestion).
Interesting, but that is an old T3/T4 based turbo with a fancy compressor wheel is it not?
I thought the 5558 was something special in terms of being all new gen wheels and what not..
My aim is sub 300kw with as much area under the curve as possible, while sticking to a sensible rev limit (thus the decision to go 256/256 poncams).
I might need to look into these smaller PT's now i guess.
Hahahha in that case Sean is going to hate me in the morning hahahahahah
Kando T67-25G and Tial MVR off exhaust housing, manifold, dump & screamer $1250ono
This on a 25/30 = NUTS, Turbo 4 months old and still under warranty!
Still available $1250
Apexi PowerFC + z32 afm suit RB25DET $1000
Edited by 32TAXI
G'Day Kando Klan, I just ordered a 40mm Turbosmart gate (with 18psi spring) from the US, now need to order my kando - would love 300rwkw and the T67-25G (R34 GTT NEO) but it will be a low mount on stock manifold with cross-over cooler pipes, fully street-setup, hence going the TD06SL2-20G 10cm.
Is this the one I should order:
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Non-AntiSurge-TD06SL2-20G-w-T3-10cm-V-Band-Housing-/290745401163?pt=AU_Car_Parts_Accessories&hash=item43b1c6bf4b
I know this will be very lucky/stretched to make 280rwkw on 98, but theres no other option for a hard-pulling stock setup, from my limited knowledge.. :wacko:
Way too big, I just finished a 6boost/T67 combo for Josh and it barely fit between the rocker cover and the strut tower. The hot side cooler pipes had very tight bends as the comp cover outlet had to point straight down.
That link I posted for the TD06SL2-20G T3/10cm/V Band/No anti surge is the correct/ favorite one? Need to order.. Dont know if I went too big in spring choice for my 40mm compgate - 18psi..
http://www.ebay.com....=item43b1c6bf4b
Plan is to get tired of the td06-20G in two years, get a top mount mani, relocate cross-over pipes, modify/extend dump n plumb-back and order T67-25G comp cover and CHRA -noting the rear housing is same as the SL2-20G.
Edited by rondofj
That is the correct one, and you will be able to do what you are suggesting, with some manipulation of the gate pipe.
18psi spring will probably be OK, might not need a boost controller haha.
hopefully the gate comes with 2 springs, so you can remove one for the tune and then pop it back in for its final run.
You obviously don't k ow how much I have had to spend on fabrication do you Ron..
Yes the Gtx would have been a few hundred more, bit the setup would be much simpler so I wouldn't be relying on alot of welding..and it makes more power..win Win :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
