Just email him instead, and ask for a discount while your at it!
email him your details and ask for a paypal invoice, just say can you please do this turbo for a discounted price because we are not using ebay? thanks.
he will reply with the invoice and probably 5% off
[email protected]
I contacted him on Facebook and he said non antisurge should be back in stock August
Well I can see a few non anti-surge models there and it IS currently August... that being said, nothing released on anything that I want atm haha
Edited by Reflector
Has anyone else had issues getting a response from Eiji (not sure this guy is really Japanese!) when there are problems? I ordered a turbo water and oil line kit from this guy and the oil line was missing. I have emailed him several times but he will not respond. I have been waiting about a week and a half now. Looking through his feedback it seems to be a common trend.
Ya i had issues- sent him coupla emails last week as I wanted to buy a TD06 but didnt hear from him at all so not buying the bloody thing haha. Going Garrett now, pay more for something thats well proven, but I still need to buy lines n gaskets from this Kandomaniac so bit worried there haha..
Havnt had any dramas of kando myself and to my knowledge several mates have had positive feedback,fair enuf one of them was sent wrong fittings but within 36 hours he had the right gear at his door...Id say he may be wery busy
ill be sending back the td06-20g 8cm internal gated turbo kit and swap it for the external gate version, any suggestions on the gate size? ill be running a rb25
rather than waste money on postage sending it back, just ask him for a discount on the external gate housing.
you will need a 10cm housing for the RB25, 8cm is 2L size.
From his facebook it looks like he came to Australia to world time attack so might explain delay in reply.
id like the set up for drift use, would that be the choice you reckon?
Did anyone ever get results from a modified L2 8cm with the billet wheels and BB core? (probably on a 20, but a 10cm on a 25 is also good)
I know Roy had one sitting around but I don't think it was ever tested.
Back to back on the same car would be interesting to see I think.
Edited by Wheezy
I sent him a message via ebay regarding a few products on thursday last week. I think there's only about an 1hr time difference between Japan and here so I assume he's either read and disregarded it OR, he hasn't been on for the last few days.
I'm actually considering contact KAMAK dynamics and getting a quote off them. Anyone dealt with them or just kando dynamics through ebay?
I'm pretty sure they won't sell to the public, need to go thru a reseller.
somebody mentioned eiji was down at wtac so he wouldn't have complete access to email or eBay.
patience lol
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
