Won't fit on his manifold though.
I'd go the TD06 and enjoy the response if it's a street car. I love the way my T67 brutally ramps onto boost, but if I was using it daily the lag would horn me.
Noob alert!
My 10cm rear might just rock up on Monday, and I'm tempted to fit it up over xmas. Am I right to think it's held on by a clamp? I've never pulled a turbo apart before. If it's fairly easy to do I'll definately give it a crack.
Cheers guys!
edit: Just realised I can look at my other Kando to see how it comes apart *facepalm*
Edited by Run-It-Hard
is it?
boost doesnt kill engines...
mercury motorsports run 40psi thro their stock rb26 lol
Heat(through high boost) kills engines by detonation right? I am sadly only running 18psi on my R34 RB25det due to intake temps approaching 50deg C, was hoping for 22psi :(. Precision 5558 0.63 making 286rwkw
WMI :)
the t67 made 294rwkw on 18psi
Which means the 5558 is not doing so bad 286rwkw @18psi compared to the T67 [email protected] as the T67 is bigger; m thinking of changing my cooler piping AWAY from fan and radiator to make a sort of a rounded 'V' piping instead of the typical rectangular 'C' across the engine to keep temps cooler and allow me to run at least 20psi, heck even 20psi is too low for me.. Do you guys reckon the V piping will improve things (cooling) a bit??
And sorry for spamming the Kando thread aargghh
Edited by rondofj
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
