sounds interesting, although be expensive compared to one big china single, people more commonly use
cheers
darren
yeah i hate singles on 8's im a symmetry kinda guy :P would be happy to pay ten times the amount just to have twins... plus the results are better.
Bit delayed though now, the stupid dry sump setup has gone missing.... DHL are trying to track it down
that looks to be a highflow with stock housings, prepared by sir kando himself. looks to be a new release, nobody has one yet.
i would be interested to see how that performs against the staple GCG or hypergear. Price wise its in line with the hypergear but seems to have very different specs.
A T3 stage 3 rear wheel with a 20G sized compressor. The T3 stage 3 is similar in trim to the TD06SL2 turbine but is larger in inducer diameter.
Would be interested to see the results.
Interesting. The stage 3 Sierra wheel was that I've used for high flowing 5 years ago, same as the old school TR44xx turbos. I've also bought some of those bolton turbine castings, They are a modified KKR430 .58 turbine housing. Will be building a new billet bolton turbocharger with it soon and making sure it has the best power/response curve.
it would be good to see you use some smaller trim turbines Stao, your current range all have larger trims than their garrett equivilent which some of them are already on the big side (GT30 v G3 wheel)
Dave it says 15psi actuator and 2.2 bar limit lol
Would you say it's smaller or larger than your pu highflow
So its a sierra rear wheel, usually they use the 58mm V-trim or H -trim comp wheel for those, not a 52mm. Been the staple
diet of hi-flows since jesus was around..still work, with a 58mm comp wheel they will push a barge ass R33 Rb25 to 120mph traps, and
vl manual turbos faster again.
cheers
darren
Edited by jet_r31
Whoa that's a lot of speed out of a liner. I wonder why kando went for the little comp wheel?
to my understanding these old tech wheels are still I'm circulation with some of the biggest name turbo builders out there.
Might talk to a mate and see if he wants to try one of these
oh yes...i drank a bit yesterday...
:blush:
cheers
darren
my car is not a barge ass :angry:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
