Hi i need a new turbo asap and dont really have time to read through all these pages but basically does any of the TD06 turbos bolt to the stock R33 dump pipe? I noticed on Kandos ebaystore they had one that does seem to, it says it uses a stage 3 turbine does anyone have that turbo or know anything about it? I'm really only wanting 250ish rwkw with good responce and was considering a hypergear hi flow as i have a op6 housing sitting around but i just discovered this thread so am now confused which way to go, please help.
The kando highflow is not tried and tested yet, but is the only one in their range which will bolt up.
Your best bet is to send your shagged turbo to hypergear and get someone that many people have bought and know its good.
Bear in mind you cant just slap the thing on and wham get 250kw. You will need an ecu and the rest of the supporting mods.
Correct. A TD06SL2 20G is the weapon of choice if you want to go that way. It has been done and 260 was easily hit on 98 by 2 members... 300 when running E85 with supporting mods.
Bear in mind that requires an external wastegate also, which will need to be plumbed off either the exhaust manifold or exhaust housing. Despite the turbo being $700 odd you should budget up to $2,000.
In light of the above 250kw is arguably better attained from a <$1,000 hypergear 2IU 'standard highflow'. Have a read of the HG thread and you will find user reviews from people who have put them on near stock cars to people who are using them in track cars, good reliable option which will bolt straight back onto the car without further modification (other than EFI type supporting mods as mentioned prior).
Please read the many threads the forum has, you will be able to form your own opinion on where you want to go from there.
I second this....
Yes, it is a hybrid TD06SL2 with his billet 71 and 74mm wheels.
Again you still need to budget at least 2k to have it on the motor, and the above 300 supporting mods are arguably a lot more difficult than the those for 250 (need to move to E85, external gate, so on and so forth).
I know people who have done ~300kw @ hubs from stock EVO 9 turbos as well, as well as EVO3 16Gs with the bigger comp and turbine housings. We are going the non-EVO fit EVO3 spec 16G with 8cm housing so I'm picking we'll be able to make some decent power. The car only has a 2.5bar sensor so we can't get too carried away with boost, but I am sure we'll still get OK results :)
tractor SR's are a long way from 4g63's though.
Absolutely, we're not expecting magic. The old PE1420 delivered all that was needed of it - so as long as the 16G at least matches it's flow (no doubt it won't match it's response) it will be considered a success. Turbo is ordered, hoping it will be here next week :)
Don't break my heart :(
WOO HOO!!
LOL well lining them up might be possible soon, the new bearing carrier for my clutch finally arrived so im getting BUSY.
Regarding cancelling out we're both guilty so don't start :rolleyes:
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
