Yeah, I'm not sure which one to go with, the TD06H comes with the T04R compressor aswell.
I'm picking out of these 4:
T67/T04R billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-T67-w-Garrett-T04R-wheel-T3-10cm-Nissan-RB25DET-/291177385706?pt=AU_Car_Parts_Accessories&hash=item43cb864eea
TD06H/T04R billet compressor - Antisurge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-TD06H-TE06H-w-Garrett-T04R-wheel-T3-V-Band-10cm-/281375447822?pt=AU_Car_Parts_Accessories&hash=item4183489b0e
T67-25G Billet compressor - Anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Anti-Surge-T67-25G-T3-10-cm-V-Band-Housing-500HP-/281375446227?pt=AU_Car_Parts_Accessories&hash=item41834894d3
T67-25G Billet compressor - Non anti surge - 10cm
http://www.ebay.com.au/itm/Kinugawa-Billet-Turbocharger-4-Non-Anti-Surge-T67-25G-10cm-A-R-73-T3-V-band-/291181230987?pt=AU_Car_Parts_Accessories&hash=item43cbc0fb8b
I'm guessing the 4th option would be the most responsive seeing as it doesn't have the antisurge housing. The TD06H being the laggiest of the 4 having the bigger 58mm turbine, but would flow more top end? Does anyone know how a T04R performs against the 25G compressor? Which would be the better option for a street car.
If you're purely looking at the Kinugawa range then on a RB25 you'd look closely at the T67-25G and E85.
You might also look at the Hypergear derivative, evidently his thrust bearing is a worthwhile upgrade - unless Kinugawa are/have incorporated something into their range.
I would like to leave room for 350rwkw
I think the Kando one maxed out at less than that from his testing, but that was with the cast compressor.
That is GTX3071 territory on e85 with much better response.
well the choice is easy...your only choosing from 2
you can't run a66- 67mm T04rcomp wheel with that turbine, unless you like lots of lag, not much power, peaky all or nothing delivery and get flogged by everything
you need at least a 65mm turbine to drive that comp wheel..
history has proved it over and over again..vl rb30 owners where doing stupid shit like this 15yrs ago..
cheers
darren
Edited by jet_r31
figure looks stupidly high for only 98 and low boost. but my t67 is up around 360kw atm on 22psi e85.on song around 4k on road.
car went in for tune on bigger boost last week, but fuel pressure is dropping off above 6k so chucking in walbro 460lph pump to see if that will help with the problem.
yea just bp 98. really happy with results so keen to drive it. should go 400. pluss on e85 and more boost.
but it will stay how it is plenty enough for drifting
Any more info on setup? Cams etc..
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
