Looks nothing like the external Vband housings I usually modify for external gates off the housing. Why do you have your heart set on a 39mm PT gate? I can get Turbosmart gates pretty cheap atm...
Anyone here used one of these??
http://shopping.kinugawaturbo.com/kinugawaturbochargerbolt-on24inchesnissanskylinerb20detrb25dettd05h-16g8cm10cm-1-2-1.aspx
I was thinking of getting one and the garret billet wheel has caught my attention.
(Going on RB25DET NEO)
Edited by vodkashot
Nothing inherently wrong with the rotating bits. The housings are likely to be physically small and not capable of flowing what the wheels can push. They do build turbos with housings more commonly fitted to those wheels.
If you want "bolt on" Kinugawa then maybe look at the TDO6SL2-20G.
Hey guys, My R32 goes in for a tune on friday. Im hopefully looking to get atleast 300rwhp. What do you's think would be an estimate of what im going to make.
The mods are - Stock Rb20det
Td06-20g 8cm sl2 v band on stock exhaust manifold
38mm Tial External Gate
18 pound boost
550cc injectors
255lph fuel pump
z32 afm
Nisstune.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
