does anyone here have dyno graphs of the kando td05 18g and td05 16g on an rb20? ive been searching through and getting mixed results but not too many graphs, i'm considering getting one of these turbo's and would like to compare spool times mainly so boost/rpm/power graphs are much preffered, thanks :)
Do they even sell these turbos anymore? I don't see them on their site anymore.
yep they still do, check their ebay store, and even though it doesnt have it as an option on the ebay store you can get them with a billet wheel and 9 blade turbine wheel (asked myself), im possibly getting one of these turbo's for my rb20 and just wondering what the response/power is like from people who have had one of these on their rb20
  • 4 months later...
  • 1 month later...
Hi guys! I read, read the topic, the result is some of the turbines? Price quality? Trusted by themselves? Let's say if we talk of the TD06 on RB25 neo6, 1kg every day to ride on the opening event and any blow 1.2-1.3? It is necessary to consider all these turbines? From the machine is required - town riding 300-380ls.
Sorry if something goes wrong with the wording of the proposals, as using an interpreter.
After many years i finally got around to tuning mine. RB25, TD06 20G 10cm rear, on e85 with all sorts of supporting mods. 17psi straight off the external wastegate so no more boost was added with my boost controller due to the rear brakes sticking on.
Keen to get out and drive her now thats for sure!! Will re book for more boost after the new year!! Really happy with the results.
  • Like 1
  • 4 weeks later...
I have a genuine GReddy TD06 20G, albeit the L2, and Mine also Dies off up top like yours does. Mine dies off even harder. We think it was due to having a f**ked cat. Now had 3" straight pipe exhaust.
Does show the Kando's perform similar though.
My Results were very similar... 270kw, 430nm, on 98 fuel, with stock plenum, GReddy manifold. same boost.. Would have been almost identical on e85.
post-27211-0-64464800-1390218028.jpg3
Now have 264 cams, E85, new ecu and other stuff going in.
Well done. Be good to see the outcome with more boost. ;) It'll Be a blast to drive as it is.
xpost-27211-0-64464800-1390218028.jpg.pa
Wow both are really close. Just shows that e85 does give you that little extra.
I have Tomei pon cams witch I think has helped the top end to open up a little more. Interested to see your results with the new gear going in and on E, when I have cash again ill rebook mine and update again!
  • 1 month later...
You're wanting to go with a completely different compressor wheel. A housing profiled for a 25G won't work with a 20G wheel.
Buy a complete turbo. What are you hoping to achieve with the downsize in cold side spec?
I'm just about finished my rb2530.
Im gonna get a tune for both t67 and td06 20g.
That way I can decide for myself what I like best threw the seat of my pants.
Not interested in dyno numbers. I'm interested in what I have under my foot. It's purely for street now. But I'd like to have the option of changing turbo to suit my wants and if I don't like it il change back. (I can burn money easily) but I'm not getting gt3076
  • 3 months later...
I have ran a TD06-20G with a 10cm housing and 8cm housing on an RB20. Difference in response is HUGE. No difference in power
I have ran a 12cm housing and 10cm and 8cm housing on the same TD06-20G on an RB25 and the response is light years different again. 8cm was mega punchy but fell over after 6,000rpm. The 12 cm was laggy and basically the 12cm-20G on the RB25 was the same as the RB20 with 20G and 8cm...so big step backwards.
The 10cm was the sweet middle, pulled well to redline but certainly wasnt as violently response in the 3,000rpm range as the 8cm
I quite liked the 8cm on the RB25. If my car was purely street I would have kept it as it drove like a diesel truck. But the lack of top end would have annoyed me when driving at the track
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
