Very nice :rant: How are u feeling with that kind of power and stock internals?
Is the car driven often? How many KM are on the engine? Whats minimum boost you run?
What boost is the efficiency range of the 3037?
And whats the approx cost of the 3037?
  • Replies 125
Fair bit of extra piping, WTF???? dude, it could be 300 metres long and it would make stuff all difference, if you look at the stock plumb back pipe its actuall about the same lenght as mine, and FYI, it IS a plumback BOV.
Knore, no probs, stock internals are fine (decompress the engine thought), daily driver that gets regular doses of WOT. Car did around 10,000kms on that turbo ( a bit under actually). Boost, efficiency is around 0.8 to 1.2, thats where they really seem to do amazing things.
3037, depending on where you buy them, between 4-6K new
Steve the turbo you used was a normal HKS GT3037 with a .87AR exhaust housing ? Does this mean the manifold and exhaust housing have the T28 flange ?
I was wondering about trying one of these (Garrett version same wheels) with a 1.06 housing on my RB26/31 . Most people are saying the GT37 compressor won't keep up with three litres so go a GT35R . Whats your opinion ?
Cheers A .
discopotato,
It's common to run twin 3037's on the Rb26 for 800hp applications, so I think a single would be a bit breathless.
Steve,
Finished the engine build, and it's incredibly strong, pulls from way low down and is much more driveable than it ever was. It's got a really relaxing delivery, with a stupidly wide power band.
But then I took it back off the road, to fit larger injectors, a proper fuel system, and practically all of the Earls hose and fittings catalogue. It's got the 'show' and all it needs now is a proper tuning session to complete the 'go'.
I'll post details when it's all together, shouldn't be much longer now.
Oh Steve - stocking it hey..... Bummer.
All that time and $$ you put into it - I feel for you buddy - Must have been a hard decision.
I've been thinking the same - or at least selling the car complete and moving to the next project - But then I think of all the dam $$ i have spent on it and just can't bring myself to do it...........
Good luck with it man.
Cheers  A .
Hmm, well it was the 3037S 56T, yes it was GT25 flange.
Doubt it would be breathless - with a 3L bottom end, you could easily achieve 350rwkw (veilside has had 700rwkw with two 3037s on a 2.7L rb26).
Combined with the 3L torque, it would be quite formidable as a street package. Hell, I had 321rwkw, not in shoot out mode on a 31deg C day with dyno dynamics dyno. I had to spend alot of money to get traction, and even then managed to light up the rears at 100kph without any problems at all. If you want early power, use the 0.87 housing, if you want a bit more sanity, larger would be better:)
I wouldnt recommend garret, I have seen a few GT30s (garret) that start boosting hard around the same place mine did, but with a 0.63 housing - compared to my 0.87. HKS turbos come in early, and dont really run out of breath from what I have seen - as long as you dont run the boost out of the efficiency range. If you think that some local company can produce a turbo that does as well as a HKS - good luck.
Here comes the old 'garret is as good as HKS' debate, but imo, you are fooling yourself if you think so. dont scrimp on a turbo, it is the heart of a turbocharged car.
JasonO, good to here, hurry up:)
B-man, yeah it was a bit painful, but there was no way I was going to sell it to someone at a fraction of the worth - and I got more money this way. the worst part was it was setup just nice, handled really well and was an absolute pleasure to drive, peak hour or on open roads. I miss it already:( dont think I will ever own a better car.
  • 2 months later...
I know of a rb25 making approx 320rwkw with standard internals. How ever, i have only seen s2 motors make over 280rwkw on standard internals and hold up
It wasn't really a standard RB25. Sure it had stock internals but it did have a lower comp ratio (thicker headgasket) and also had a lower dynamic comp ratio as he was running larger cams.
All of which help to aid off the nasty detonation that kills the Rb25's cast pistons.
I don't think it was even really driven that much. :(
So is there much of a difference between Series 1 RB25s & Series 2 RB25s.... I've got a 1995 r33 Series 1.5, which engine does that have...
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
