Done.
LOL...I don't mind...I just dont think they'll be as good value as a set of BC's!
I'm just worried that the front bar won't last long when lowered...look at the last pic! I won't be able to get away with that anymore!
You're right; BC's are the biz. Sorry Iain :nyaanyaa: It'll look solid with a bit of low.
Don't worry about the front bar; thats why touch up paint was invented...
i like a VERY firm ride, and the nismos arent stiff enough for my liking.
So if you like your ride so firm, what setting are you running on?
I think I saw where you changed yours from setting 3 to softest setting.. Is that right? If so, that makes the BC's a pretty firm coil over IMO.
At the risk of being too far off topic, I'm wanting BC's to lower the car but don't want to impact ride too much. It will already be affected slightly with the swaybars that are coming soon.
Can anyone tell me how much ride "quality" is affected by shock valving & how much by spring rates?
I can get the BC's with lower spring rates but not shock rates / valving.
It was actually me who wound the damping back to full soft. That was after I fitted the GB swaybars, as I'd been using the firmer damping to make the car more direct on turn in. After the bars it became like an apex seeking missile, so I was able to back it off and still have brilliant turn in, AND excellent ride. They have an extremely compliant ride. Iain runs his much firmer than I do, but I don't feel it's necessary.
i wound mine up further. im running about 9-10 in the front and 7-8 in the rear. i think im going to soften the front and stiffen the rear for some sideways bias.
front springs are 10kg/mm rears are 12kg/mm
one day ill go even firmer and see how that goes, but not on sydney roads lol
OK, thanks Dale.
Ride comfort is a very subjective thing. Your comfortable ride could be my kidney damaging, wife screaming future :blink:
I tend to think your ride probably is excellent, but I lack the confidence to just go & buy the BC's with standard spring rates.
It a little puzzling why most guys (maybe Iain excluded) run the damper settings pretty close to the soft end of the spectrum. You'd think that if BCR got their product right, the majority of M35 drivers would be on about the middle setting, with the Iain's of the world at the upper end and luxo lovers like me at 5 clicks from soft :/ .
I hate the idea driving at full soft and then having no where to go in that direction for those special occasions when comfort is most important.
Would 2 or so kg less in spring rates help or just bugger the handling?
to be honest they are real nice on the softest setting. not harsh but quite firm. nothing that even MY wife complained about. hence why its taken me 3 goes to get to the adjustment im at; mostly so she doesnt notice. now that it hurts her chest (like my old car) she is starting to complain lol
i dont think the spring rate would affect it much, that said, apparently scott has his BCs set around the middle of the setting, the damper settings may go even softer. but youll need to ask him, i think he has the 1100 model (cant remember the exact model sorry) however dale and myself both have the 1300 BC set.
ask craig about the nismos if youre interested in them, also stephen when he is back online as they came from his car.
Had a busy day on the Stagea today... Had 4 new Falken 912 tyres fitted today and a 4 wheel alignment. Think these will be better than my cheap RV tyres.. lol
Also made a little mod to the blow off valve to block off the small hole to improve boost response.
What did they find with the alignment? Any clue to that weird Tyre wear?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
