nah factory wing, same as the one on Alex's PM35 and another one that was at the meet.
pic for you bigkev!
worth it purely because its my colour already
Edited by zei20l
lol it clips on, but there are 4 or 5 bolts underneath. youll need to remove the inside trim from inside the hinged glass tailgate section.
not a massive deal.
has your himount stop light died? mine too. i have a spare, but the non-wing models are different
Mine hasn't died- get back to me in 4 years time... then it will be as old as yours....:ph34r:
did you get a chance to check that diff out on the weekend? I know how far hassling you for parts will get me :P
nah i havent been there, but what am i checkout out on it? i thought you were coming to look at it?
I finished making the new fuel pump assembly today, all ready for the triple teflon braided lines. One Walbro HP and -6 line for each rail, it should just be able to max the injectors if I need it to. lol.
Hopefully the gtx turbo ships soon... :rant:
:worship: That looks like it'd set alarm bells off with ASIO :rofl: May have to get some details of your construction of this... eventually !
haahh thats some cool shit right there dude!!
not bad at all!! very clean
paint it black and no one will know its not factory.
how many PM35s do we have on here?
Cheers, yeh considering painting it black, or polish it a bit more.
I'm just not sure what to do with the breather line that usually goes back into the intake. Either make/buy a oil catch can or get a nipple welded on to it.
By the looks I need a new rubber joiner(from pipe to TB), it's starting to crack, so that'll be next!
just get a similar one like the blue silicone joiner you have.
then cut one side on a angle that suits the bend..or a bend silicone joiner
cutting the end is what I did and it works fine lol
make a nipple and put it back in if thats where its supposed to go. again, it will look factory and oil vapours will go back into the engine where they are supposed to lol
Not really. They go back in their because it was the easiest way from factory.
It's a proven advantage to vent them somewhere else. My RX7 has the breather go into a bottle... The optimal setup is a 2L+ bottle, with steel wool baffles and a drain back to your sump.
Oil vapour = lower octane of your fuel and grime up intake. Which we all know is an issue on VQ motors. When I ripped off my intake it looked like someone had poured a bottle of oil through the intake. (Given it probably had never been pulled off its whole life of 200,000km)
Yeh, i'll probably do that, or just get a silicone joiner the same as the black pipe, just a little more dollars.
Edited by JayM35
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
