You may find that once it it being controlled by the ecu, it actually pulls closed. Most throttle bodies have an air bypass port to control idle, and the butterfly seals completely.
Not this Throttle Body Dale. This one has no bypass.
This is why you have to clean them on a occasional basis or the car can start to stall.
Cheers
Andy
Cheers
Andy
Definitely explains the reason. A small amount of blockage would cause issues.
You learn something every day pinch.gif .
yeah spoolin has 19x9.5 +40 with a 12mm spacer so effectively a +28 offset... but they do stick out a bit - he has stretched tyres and they dont scrub.
but talk to him about tyre wear. with that width and offset you cant take out much of the camber or they will scrub the guards, so tyres wont last long.
Cheers mate, shot him through a PM.
I'm also looking to stretch so hopefully it won't rub too much.
Would a narrower rim help at all? The only reason I ask is the rims I'm looking at only come in +22, 10 or 0.
A narrower rim will always help. As I mentioned I am running 19x8.5 +22 and thats pretty flush.
You can work out how much more they will come out with the following equation:
(width (in inches) x 25.4(mm)) Divided / by 2 - the offset is how much rim comes out from the hub face
So mine that are flush are 8.5x45.5 = 215. Divided by 2 = 107.95. Minus the +22 offset = 85.95mm from the hub face. And thats about flush with the front guards: see pic below.
So 9.5 +22 would be 98.65mm from the guard. So it will stick out a further 12.7mm than what I have.
Ben.
Edited by bbenny
Ben.
That is a really good fitment...
Ben.
That looks perfect
I'm looking at something like this:
Yeah they would look awesome! Ce28 copy? are they Vaerrston or whatever the brand is called?
I should also mention if you run 9.5 you cannot run an offset higher than +35 or they will rub the front suspension arm.
Will look awesome!
I'm thinking of getting new wheels, I love my wheels but they're just a little too small. 18x9.5 at +15. I'll see how it looks once it's slammed with 25mm spacers.. So -10 lol
They are indeed.
So really my only option is the 9.5 to get a few tyre options and the highest offset these come in is +22 so rubbing on the suspension won't be an issue. I will do some ringing around RE 19in tyres to suit an 8.5 as if I can find some at a reasonable price I'll go that way.
They are indeed.
I think you said you were in Adelaide? Call Mark at SA Motorsport Tyres on 0409288380, tell him Ryan from Pure Motorsport sent you. He'll look after you.
Removed the Walbro fuel pump today and reinstalled the stock fuel pump and fixed my big hesitation problem around right hand corners ... :)
No issues supplying enough fuel with the stock pump?
It was well and truly maxed by 220, as the pressure dropped after that point and the injectors had to be opened exponentially to squeeze more flow out of it. Not where you want to be, fuel supply wise especially if you have stock injectors.
I may put the Walbro back in but need to do 2 things first,
1) use the filter fitted to the stock to the pump. (I think the filter fitted to the Walbro may be part of the problem. It is smaller and in less than 12 months has gone black)
2) Run the 12v power supply to the pump. I agree that the Walbro seems to perform better with the additional power.
Especially as I have the 60lb Siemans injectors to go in with the tune.
Went a bit overboard on eBay today, picked up my slimline fan ready for the front mount intercooler, and ended up getting a Nismo dash after putting in an offer... Bit sad, but ah well!
Do you have the factory Screen/Nav Unit. I saw the cluster on ebay also, but was trying to determine if it was the right cluster to suit car with factory screen (different part numbers according to Nismo catalog)?
I have a set of Nismo boost gauges. Looking for the Nismo cluster as we speak (ex Japan). Out of interest, what did you end out paying?
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
