Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
Is there anyone in SA who can tune an Emanage?
The place where I got it from (ebay store) was located in Japan, I'm pretty sure I got the EMU + harness for around $600/650 delivered.
Unfortunately they were affected by the Tsunami and they don't seem to sell EMU's anymore...
Love ebay sometimes.
Emanage Ultimate: http://cgi.ebay.com....e=STRK:MEWAX:IT
Universal Harness: http://cgi.ebay.com....=item588275acd9
MAP Sensor: http://cgi.ebay.com....=item27b7e1a13d
(Did see this cheaper sensor, but looks dodgy as! http://cgi.ebay.com....=item230fca0ec0)
Think thats it for an Emanage install?
Oh, and Informeter: http://cgi.ebay.com....e=STRK:MEWAX:IT
Sounds like it might be a useful acquisition?
dont get the dodgy ones. if they arent an accurate reading, your fuel map can go right out..
Informeters a good doo hicky..although its not really important. you can get another boost sensor and wideband into it. it will tell you your water/intake temp.. throttle % speed RPm.. but the injector duty sycle n some other stuff will be incorrect as a tune will change figures.
they only had two ECU'I bought one, then you bought one.. i tried messaging him about the profec B, but paypal sent me money back. i think his shop was destroyed in the tsunami. poor guy!
map sensor is needed the way i see it. its the safest way as your Tuner isn't simply guessing. hes calculating figures!
when you look for injectors, ask for the plugs. you will need to cut the stock connectors off and solder the new ones on. I'm using Seimens Deka 610CC and im about 80% duty with e85. work fine and dont miss a beat. they are a 4 squirter!
A wide band will help for road tuning, but the dyno should have one for the dyno....i guess if you want one..
i pulled my turbo out again, to open the wastegate up.
took me 2 n abit hours.. proud much??
opened up the wastegate. put everything back together. and no change. what a waste of a day.. looks like the actuator may be playing up :(
What was the car doing that made you think something was going on with the wastegate?
I ordered an Informeter. That way I don't have to guess whats going on and worry unnecessarily.
Probably do FMIC next. Still deciding whether to do fuel system before emanage or vice versa. Coming along nicely! :thumbsup:
You'll have to come by and do mine soon Aaron :P
lol i told scott that you needed this done.. he laughed hahah
its over boosting. would hold 15psi through to about 4500rpm and then shoot up to 22psi. felt as if the Wastegate was too small and as the exhaust air flow increases it cant push any more through the gate and comes out the fan again, only to continue boosting. I opened up the wastegate as much as i could. and no change.. looks like the actuator isnt allowing the gate to open enough...
lol if anything the informeter will make you worry more when you start seeing figures.. trust me, its why Craig got rid of his lol
Got it back from panel and paint... All new again.. Insurance company sent me a brand new wheel instead of repairing old one and bruce from mag and turbo gave me a tire to use till I save up for a new set! LEgend!
So today I pick up and fitted a black bonnet, was easy enough to change over just not to sure if its what I want anymore. Maybe after a few weeks I'll decide if I'm gonna keep it on or change it back.
What you think?
yeah was thinking roof, mirrors and the little bit behind the rear side windows need more black.
Then maybe I'll change the chrome stripping to black, then black out the headlights and foggies, tint the rear lights hmmm where to stop?
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
