Like a bull out of a gate!!!
Nice way to start ....1 day into having the car!!!!
.....I think I lasted 3 day's before I did a full dump back exhaust and another 2 weeks before the wheels....and the list goes on and on and on ect!.....4 years later and 2 things left to do!!!...maybewhistling.gif
I like to think of it as being organised. I ordered the wheels for it the same day I won the car at auction
ZOMG! Trabant wagon!
looks more like Scott's....being white and all!
....has a better looking grill than Aarons too....not that that would be hard!
Edited by Jetwreck
so if its a better looking grill than mine, its definitely better than yours
Well, I decided I would fit the coil overs today. The stock sus was in very good condition but these Tanabe coil overs ride sooooo much nicer. Not hard at all, nearly the same as standard but just ride the bumps a little nicer. It does sit fairly low with the guards sitting level with the tyres. Looks awesome!
Ill try and post a pic over the weekend for those interested.
which tanabe coils do u have? i used to use tanabe NF springs for my civic, they lower the car but only a tad bit stiffer, there was still a bit of bodyroll until i changed to tein flex...
Washed it today.
Yesterday finished my intake, took bottom resonator out of airbox cut hole bigger for 3" piping from bumper grill.
Also brought 2 more Wolf 18x9.5s, but in +15 offset, so now will be running +30 up front and +15 rear
Is the front generally supposed to be higher or lower then the rear?
It's better to have the rear a little higher, otherwise you start to lose caster; which then promotes understeer.
Even with equal front & rear hub to guard measurements; you will still have an amount of rear rake.
im not saying youre wrong, just having some input to this conversation :)
but shouldnt the rear be a little lower on a car due to the way cars corner?
Measuring from the sill panel, mine is 30-35mm higher at the rear than the front. Its hard to tell by eye that it has 30-35mm of rake now. IMO it sits nicely. I might adjust it slightly when the new wheels arrive, this will depend on what tyre sizes I end up using.
When I was younger and into Valiants we would run the rear lower than the front and it understeers badly.
And out of interest, how many of you guys loosen all of your suspension arms and preload the hub and then tighten it all back up when lowering a car? I always do this as it takes the twist out of bushes. If you don't do this it twist the bushes quite a lot. A lot of people don't do this and then wonder why the bushes wear out quickly.
Edited by slippylotion
(1)Measuring from the sill panel, mine is 30-35mm higher at the rear than the front. Its hard to tell by eye that it has 30-35mm of rake now. IMO it sits nicely. I might adjust it slightly when the new wheels arrive, this will depend on what tyre sizes I end up using.
(2) And out of interest, how many of you guys loosen all of your suspension arms and preload the hub and then tighten it all back up when lowering a car? I always do this as it takes the twist out of bushes. If you don't do this it twist the bushes quite a lot. A lot of people don't do this and then wonder why the bushes wear out quickly.
(1) IMO i wouldnt have the rear lower than the front - considering its 4WD and the body under power is always going to be lower at the rear under these conditions.......... also less understeer!!!
its not like we need to have more weight over the rears for traction anyways
(2) yep.... otherwise u could also find your rear springs move round each time u jack the car up!!!
Not sure what you mean here. My rear is higher than the front. Don't look at wheel arch measurements, look at the sill panel, this is the level line of the car. Wheel arches front to back are often not the same height.
How will the spring move around when they are captured?
Yep, always crack & loosen arms to settle bushes. Usually just run the car up on some ramps once I'm done; easier than preloading arms.
I think the rake on mine is only 10mm front to rear (rear higher).
Iain, I stand by my "Loss of rake equals increased understeer" theory, but it must be in relation to original heights; not just a blanket "Rear high equals awesome handling", probably should have clarified.
They poke out a bit, but nothing too crazy, just gotta roll the lips on the rear and you are sweet. just stretch some 245 tyres
Apologies for harping on about wheels so much - reckon a 19x9.5+15 would fit? It looks as though 19x9.5+22 is wide without being ridiculous, the 7mm should be pretty safe, yeah?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
