Oh yeah! Just checked the thread again, was around 230.
Unrelated, does anyone know if the Xtrail licence plate lights are the same size as ours?
Im looking at a wireless reverse camera, replaces one light with the camera and an LED light for the plate. Says it fits Xtrail and Quashquai (or however that stupid name is spelt).
Ok, well after what feels like forever, and is probably 6 or 7 months, I have finally got wheels on my car!cheers.gif
Details: Wheels - SSR Type F 19x8.5 +22 in Matte Black and very light! (JDMConcept)
Tyres- Continental Extreme Contact DW 225/40 19 (tirerack)
This is the same wheel specs as Bbenny's Enkei GTC01's. Thanks mate for putting up with my PMs about wheels all the time!
Very happy with the outcome - the fit is just right, I think it looks great. Pics taken really quick, with bad Camera. The car is Lowered with Eibach springs. Only criticism is that the rear looks a little high in the pics (car is on downward slope), but in reality I can just fit 2 fingers between the tyre and arch. The overall height is ok for me due to the driveway- lower I'd be scraping. Really, the photos don't do it justice. Nick- You'll have to take some good ones for me!
New Wheels! Stock Wheels------------------------->
Edited by PN-Mad
The car was parked downhill, so it didn't do it any favours. I think I need that clearance though, the Mrs has to go over epic speedhumps at work!
nice!
i have one too :)
Alex, the wheels look fantastic mate. good choice
Any idea what sort of power increase it gave you after installation?
Did the note or volume of exhaust change?
Edited by Ross
i can tell you that mine made zero change to anything. possibly due to the fact its still in my garage lol
i would imagine as its a de-cat pipe (and youll be installing the cat after this pipe *wink*) that the note would be more raspy and possibly higher pitched. but it will depend on your existing exhaust and if you have an aftermarket dump pipe
Finally got my new headlights in; when I got them there was an amber LED array that lit up with the driving lights/squid rings; was pretty sure this breached ADRs so Brad lent me a hand rewiring them up to the blinker; had to wire in the old blinker globe to up the resistance on the circuit to slow down the blinks too. A little hodge-podge, but the end result looks good imho. Hopefully the seals hold up :rofl:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
