Oh yeah! Just checked the thread again, was around 230.
Unrelated, does anyone know if the Xtrail licence plate lights are the same size as ours?
Im looking at a wireless reverse camera, replaces one light with the camera and an LED light for the plate. Says it fits Xtrail and Quashquai (or however that stupid name is spelt).
Ok, well after what feels like forever, and is probably 6 or 7 months, I have finally got wheels on my car!cheers.gif
Details: Wheels - SSR Type F 19x8.5 +22 in Matte Black and very light! (JDMConcept)
Tyres- Continental Extreme Contact DW 225/40 19 (tirerack)
This is the same wheel specs as Bbenny's Enkei GTC01's. Thanks mate for putting up with my PMs about wheels all the time!
Very happy with the outcome - the fit is just right, I think it looks great. Pics taken really quick, with bad Camera. The car is Lowered with Eibach springs. Only criticism is that the rear looks a little high in the pics (car is on downward slope), but in reality I can just fit 2 fingers between the tyre and arch. The overall height is ok for me due to the driveway- lower I'd be scraping. Really, the photos don't do it justice. Nick- You'll have to take some good ones for me!
New Wheels! Stock Wheels------------------------->
Edited by PN-Mad
The car was parked downhill, so it didn't do it any favours. I think I need that clearance though, the Mrs has to go over epic speedhumps at work!
nice!
i have one too :)
Alex, the wheels look fantastic mate. good choice
Any idea what sort of power increase it gave you after installation?
Did the note or volume of exhaust change?
Edited by Ross
i can tell you that mine made zero change to anything. possibly due to the fact its still in my garage lol
i would imagine as its a de-cat pipe (and youll be installing the cat after this pipe *wink*) that the note would be more raspy and possibly higher pitched. but it will depend on your existing exhaust and if you have an aftermarket dump pipe
Finally got my new headlights in; when I got them there was an amber LED array that lit up with the driving lights/squid rings; was pretty sure this breached ADRs so Brad lent me a hand rewiring them up to the blinker; had to wire in the old blinker globe to up the resistance on the circuit to slow down the blinks too. A little hodge-podge, but the end result looks good imho. Hopefully the seals hold up :rofl:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
