i actually thought it was my external BOV causing the richness........ maybe ill plumb it back and see if it still occurrs.
maybe its programmed for overrun for big burble with big exhaust sounds :P
Lol, I wish it worked like that. With the amount of unburnt fuel coming out the back, I was surprised there wasn't 2 feet of flames. No such luck however.
Did anyone with an intake notice that they ran particularly rich when backing off? Before the e-manage tune of course.
I've tuned mine so the AFR's are good at light to medium loads (runs really nice actually), but when I lift off after accelerating, the AFR's start to go lean (as they should when coasting) but then go full rich (10:1 on my display) for a few seconds which causes a heap of smoke out the back.
I can post pics of log graphs if it will help, but it really just displays what I said (I hope :blush: ). I'm thinking of returning the intake to stock to confirm the problem goes away and then get some graphs to compare with the new ones, but that will require some work...
As an aside, I don't know if anyone else has seen this, but it appears to me that the standard ECU has another map that it refers to after a certain rate of acceleration (or throttle application) occurs. I found this out because my AFRs remained essentially unchanged at the top end regardless of what I did to the AFM signal at those load points. It is like it ignores the AFM signal & does it's own thing.
Where have you plumbed in the BOV, it sounds like you haven't merged it into the intake properly...
I made a new intake to throttle today, to try and fit the electronic throttle (without the butterfly in it). The cable throttle has been working flawlessly but the cams still arent working, even with the gutted electronic one still plugged in. >_<
The turbosmart BOV needs a much stiffer spring too, I had it venting and it leaked badly, I removed the hose and it still leaked on boost. Blanking the hole caused the hoses to pop off, ruining the under-bonnet sound deadener.
The Fcon has a miss which im not happy about, probably caused by the emanage being in the circuit still. That and the cams not coming on make it feel very laggy, it feels dead down low until I get above 4k, looks like the Emanage is the better option at the moment. I may end up going with the PS2000 soon if this goes nowhere.
pheeeeew
saved me some $$ there...
so u can't get it to work on its own correctly?
Edited by GoldZilla
Craig fitted the new bushes to the front end tonight and it is a massive improvement.
I have been getting this vague wobble in the front end recently and by replacing this bushes this has improved the feel in the front end dramatically. :thumbsup:
best mod ever hey?
The throttle wouldnt work with the short time I had to tune it so I just fitted the old cable throttle until I could work it out. Runs fine just that the stock ecu is in limp so the cams wont advance. Theres no way I could live with a laggy pos like this, the cams allow around 30kw of midrange right where you need it.
Its a completely different feeling having full control of the engine and throttle, for a change. :rolleyes:
I finally got my idling issue sorted about 2 weeks ago!
Yesterday (Tuesday) I got the pink slip done, then took it for a wash. :D Today it rained... :( F'king typical! I really should get a rear wing, the rest of the car stays clean when it's wet, but the air must recirculate from the tailgate and keep all the dust in that area.
it makes me wonder if that guy in NZ actually got it working.
I think if he did he'd be talking about it instead of disappearing. He did mention the shop in one if his threads so someone should call the shop and ask...
Edited by ironpaw
:happy:
nah i think he got a "HKS Rep" to do it, RIPS were doing all of his Fab work.
Lol! Stupidious Giganticus!
Must say I feel a bit stupid for defending him, he still gets on here, last active; Aug 01 2011 01:15 PM
Install must've been a raging success :whistling:
more like raging hom...:whistling:
put my new filter in, thanks jase!
He was very active here for a while, wasn't he. People are funny tho. I've got no problem trying stuff & reporting back that it didn't work. That's how we all learn & what makes this forum better than 99% of them out there.
I checked the OE pipe & the angle it enters appears to be less than mine (first pic, far side). All the original hoses were left as they were, with just an extension bend added to turn it in the right direction.
Do you think that's the issue? Any suggestions on how to improve that part of the design?
Thanks, Leon.
post-76144-0-49049000-1313621566_thumb.jpg post-76144-0-93973000-1313621584_thumb.jpg
Sounds like you need to just fit a MoTeC and be done with it?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
