Just got outbid on Mines ECU on YAJ only 5 minutes ago...Got me in the dying seconds.... >_<
Oh well.....
really?
i thought if you bid within the last 5 mins on YAJ it extended it another 5 mins?
Its possible the IM interface timing isnt spot on......
anyway, sucks that you missed out on it, would have been a nice toy!
really?
Yes, but it is 10mins, not 5.
Well that's what has always happened to me :(
No ebay sniping on Yahoo Auctions
Finally did the "wire" mod today.
I shouldn't work on cars after night shift; everything seems to take twice as long...
Edited by Daleo
Tired, eyes a bit blurry & cutting wires at the ECU. Yep, recipe for success, lol.
Lol, yeah, I might've checked everything a few (hundred) times before cutting; just to make sure.:thumbsup:
Car starts, and no fault lights.:banana: Going to wait 'till later for a test.
Mind started ticking away; had to go for a drive...:banana:
That's a surprisingly useful little mod!
Wired up a switch to reset if need be. Is it just a case of close circuit, tap brakes, fault gone?
Good work for doing the hard yards guys; riding your coat tails is a great thing.:thumbsup:
What was the "wire" mod again?
Ecu harness, Pink wire, blue trace; cut, insert momentary switch, have access to full throttle opening whenever you like.:thumbsup: Enjoy better low speed throttle response and no delay after brake application.
Every now & then, close circuit and tap brake to avoid ECU going into "Limp Mode"
Anyone else care to fill in any holes in my explanation?
And I edited your post for the (future)emanage people
once you notice something shifty going on afeter approx 100km, go for another emanage tune. much better than just resetting.
Is there any way to send a constant signal to the ecu on that wire so it thinks it's connected and won't need to be reset all the time?
Could you hook the brake pedal light switch to that ECU wire to give a signal everytime the brakes are used? I don't know what voltage it see's/needs, just thinking of ideas.
Edited by slippylotion
really?i thought if you bid within the last 5 mins on YAJ it extended it another 5 mins?Its possible the IM interface timing isnt spot on......anyway, sucks that you missed out on it, would have been a nice toy!
I don't use IM. I have a mate in Japan who was on it for me to 49,000Y (much cheaper for me this way - avoid IM's commission). I was trying to call him for the last half hour as i was watching the bidding get higher and higher to up the bid a bit, however couldn't get him on phone....I was stuck! You are right in that time is extended with YAJ - i just couldn't get a subsequent increase in bid on.....
I recently bought the ex Andy, then ex Aaron Impul ECU which i have here, and was only going to get this one to compare!
What were the specs that the comp runs with?
No idea?? That's why i was interested in comparing differences between this and the Impul...
Mine's generic tune (from memory)
RPM limit raised to 7100 or 7300 (can't remember which)
Boost raised to 1.1bar
Speed limiter removed
Throttle remap
Fuel/timing remap
Of course, the end user could specify whatever the hell they wanted (2bar boost and 7,500rom for instance) and all Mine's state is "yes, but please consider the risk"
Take your word for that info Cam. There wasn't a great deal of info on the listing. Is that info straight from mines?
You probably already know but I left the wiring diagram books with Aaron for you to collect and borrow.
i doubt it, if it detects connection while the brake is applied theres not point in having it.its best and easiest to have a momentary switch
i suggested a timer circuit, or something hooked up to the water temp. so it gets brake signal till the engine gets to 70degrees. before then you arent going to need to hammer it
but who would go through the trouble of that? lol if commsman doesnt, i dont think anyone will.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
