Far Queue. I backed the R30 into the 25G. But I am lucky. The front guard I hit is the one with the rust hole in it and I have a spare guard, so no drama. But I have buggered the R30 rear bar.
Win some, loose some.
I believe I'm expecting a photo of my Stagea in the mail from my good friends at SAPOL. >_<
Ouch... :(
make sure you credit the photographer if you use it anywhere :P
LOL. That, or stock up on protein shake mix, depending on what side you're fighting for.
should i have it before bed??
craig are you going to make it one piece? or have 3 seperate ones like your template?
Don't you want some droop? It forces the wheels to maintain contact with the road when you go over a bump. Having too much droop is bad as this will force the car to raise when cornering too much (dependant on spring rates/shock rates etc.)
Yeah, I should clarify; as little droop as these shocks allow; which is still around 4ish inches.
I agree with you regarding droop helping handling but with the length of these shocks, I was actually more concerned about getting the shock running resonably central in it's stroke to allow a good amount of compression travel without bottoming out the piston assembly.
1 piece.......I will need to test fit on your car as well though to make sure that the one I do fits all.
Edited by Jetwreck
ide be very interested as mine flung off on the freeway some time ago,
i can arrange that. we should just go to the workshop every wednesday night. we have been there pretty much every week for a month lol
I agree....I should be there the following 2 Wednesday nights anyway! Makes it easy to check over things.
I have a spare lying around, but it might be worth waiting to see Craig's "quick release" design.
It won't fit "all" :(
EDIT: fixed thanks Aaron :blush:
Edited by iamhe77
oh as in yours lol you mixed the quotes around i think.
yeh Ill wait for craigs one..if it doesnt im gonna leave it, its alot easier doing a service, a quick release would be nice though
i think a large opening under the sump would be ideal. that way you could leave the rest of the undertray in position
yeh but i cant remember how the stock one is, isnt there a metal bit around the drain "hole"
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
