they regesigned a few parts mid-way through the run it looks like
when stripping stephens wreck, he had some small bits that were better i guess. so they are now located on my car :)
maybe it fell off. more than likely did.
OR its a different design as mine is a 2001 model. stephens 2002 had a different undertray with metal supports in it.
Yeah, IIRC he bought a new "rear" undertray from Hornsby Nissan which had more metal on it.... or something
Mine doesn't look too good, only 4 bolt holes work now. Send the cad down and I will try it out on mine Craig. If it works I can sell one to Aaron for shitloads. hahahah.
I took on a little project with the Stagea.
For those who like the idea of fitting GTR sway bars to their C34 but can't be arsed forcing the rear bar to fit, check out this thread below:
http://www.skylinesaustralia.com/forums/topic/375348-upgrading-sway-bars-to-stagea/
I fabricated up some mounts so the rear GTR sway bar is a comfortable fit.
:thumbsup:
Put R32 GTR Sumitomo brakes on tonight. PMu pads.
Two issues - one, didn't cut/bend enough of the LHS stone guard out of the way - so it scrapes on left hand turns - easy fix.
two, I seem to be getting a small leak from the banjo in the back of the calliper. When I pulled up after bedding them in, there were patches of BF around the wheels, both sides. Not good. Braking performance was good, so not a massive leak. I think the OEM's are slightly different in operation. They have a little seat where the copper washer sits into the calliper. The R32's dont have this. So what I think I have to do is smooth off the surface where the banjo goes in to make it sit flush and seal nicely.
Either that, or shorten the part that goes into the calliper- thats been mentioned by other people. I thought I wouldn't have to do that because I removed the original restrictor out of the sumitomo callipers.
Anyone else have similar experiences?
Alex, did you use new copper washers on the banjos? I've fitted several sets of Sumitomos using banjos, rather than flares (as per std) no leaks, no issues. With the taper seat gone; the banjo shouldn't bottom out. Wash the residual fluid off with some soapy water and see if it reappears.
i wouldn't smooth the surface at all
it will be nice and flat at the moment but as soon as you hit it with a file or something its going to become uneven
i'd leave it to a last resort if you can
Yep, it should be fine with some new copper washers. If not, the area will need to be spotfaced to give a nice flat mounting surface.
Edited by Daleo
Fixed it.
Could not find copper washers, only seemed to sell them in imperial not M10! Nissan parts wasn't open sundays. I removed the lip off the old washers, and gave the bolt a bit of a grind down, sanded the surface smooth as, whacked it back together and fixed.
Pipster- my callipers had some kind of finish on them , a little rough in the alloy. Bit of sanding gave a good finish.
Craig came round, fixed my grinding problem... was that little bit of alloy that I should have got rid of in the first place, but it only fouled on one side, and only when turning!
So brakes are on and working a treat, so much better and heaps more confidence in them than the OEMs.
Craig also broke out the magic tool, and we lowered the back of the car - by popular request! Photos later, when I can be f'd.
So all in all, a very productive weekend - thanks again to Craig for helping me out. What a champ.worship.gif
Fixed it.
Not a problem with the help....I've run out of things to do on my car and yours is the closest to me! :P
On other news I got my head pretty much around your HKS Kit....hopefully I will get a good nights sleep tonight now.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
