they regesigned a few parts mid-way through the run it looks like
when stripping stephens wreck, he had some small bits that were better i guess. so they are now located on my car :)
maybe it fell off. more than likely did.
OR its a different design as mine is a 2001 model. stephens 2002 had a different undertray with metal supports in it.
Yeah, IIRC he bought a new "rear" undertray from Hornsby Nissan which had more metal on it.... or something
Mine doesn't look too good, only 4 bolt holes work now. Send the cad down and I will try it out on mine Craig. If it works I can sell one to Aaron for shitloads. hahahah.
I took on a little project with the Stagea.
For those who like the idea of fitting GTR sway bars to their C34 but can't be arsed forcing the rear bar to fit, check out this thread below:
http://www.skylinesaustralia.com/forums/topic/375348-upgrading-sway-bars-to-stagea/
I fabricated up some mounts so the rear GTR sway bar is a comfortable fit.
:thumbsup:
Put R32 GTR Sumitomo brakes on tonight. PMu pads.
Two issues - one, didn't cut/bend enough of the LHS stone guard out of the way - so it scrapes on left hand turns - easy fix.
two, I seem to be getting a small leak from the banjo in the back of the calliper. When I pulled up after bedding them in, there were patches of BF around the wheels, both sides. Not good. Braking performance was good, so not a massive leak. I think the OEM's are slightly different in operation. They have a little seat where the copper washer sits into the calliper. The R32's dont have this. So what I think I have to do is smooth off the surface where the banjo goes in to make it sit flush and seal nicely.
Either that, or shorten the part that goes into the calliper- thats been mentioned by other people. I thought I wouldn't have to do that because I removed the original restrictor out of the sumitomo callipers.
Anyone else have similar experiences?
Alex, did you use new copper washers on the banjos? I've fitted several sets of Sumitomos using banjos, rather than flares (as per std) no leaks, no issues. With the taper seat gone; the banjo shouldn't bottom out. Wash the residual fluid off with some soapy water and see if it reappears.
i wouldn't smooth the surface at all
it will be nice and flat at the moment but as soon as you hit it with a file or something its going to become uneven
i'd leave it to a last resort if you can
Yep, it should be fine with some new copper washers. If not, the area will need to be spotfaced to give a nice flat mounting surface.
Edited by Daleo
Fixed it.
Could not find copper washers, only seemed to sell them in imperial not M10! Nissan parts wasn't open sundays. I removed the lip off the old washers, and gave the bolt a bit of a grind down, sanded the surface smooth as, whacked it back together and fixed.
Pipster- my callipers had some kind of finish on them , a little rough in the alloy. Bit of sanding gave a good finish.
Craig came round, fixed my grinding problem... was that little bit of alloy that I should have got rid of in the first place, but it only fouled on one side, and only when turning!
So brakes are on and working a treat, so much better and heaps more confidence in them than the OEMs.
Craig also broke out the magic tool, and we lowered the back of the car - by popular request! Photos later, when I can be f'd.
So all in all, a very productive weekend - thanks again to Craig for helping me out. What a champ.worship.gif
Fixed it.
Not a problem with the help....I've run out of things to do on my car and yours is the closest to me! :P
On other news I got my head pretty much around your HKS Kit....hopefully I will get a good nights sleep tonight now.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
