Bit of a long story but my car has gone from the workshop to a tuner who has installed the G4 Link and is going to tune it tomorrow. He is a top tuner and has built a seven second R32 GTR
but he was complaining that he was having to take his M35 Stagea to NZ's most famous GTR tuner because he has the software to crack the ecu but its all in Japanese. I will try to find out more and keep you informed but it could be good news for Kiwi V35 and M35 owners. Soichi used to work for Nissan and travels back to Japan regularly so I don't know how he came by the software and whether he will onsell it (maybe to someone like Toshi). Will let you know.
Good weekend for the Stag...
New front rotors arrived, courtesy of my new friends at DBA. DBA 4000 series rotors with the new Clubspec T3 slotting:
Not going in until the BCs arrive, probably just before the SA cruise :thumbsup:
And no more pirate spec, got one of my new spot lights in:
Thanks to Simon Michelmore for giving me a hand working out the mounts for it. Ended up clearing all the broken glass out, and drilling into the old plastic mount to screw into the standard Narva bolt holes. Worked ok, not ideal. You can also see in the above photo that there's a fair gap around the light, so now I'm thinking maybe a set of squid rings to fill the gap?
Has transformed the front end:
Before I do the other one, I might move the light forward slightly so I can angle it up a bit. Also have to find a better spot to mount the HID ballasts.
Anyone happen to have a broken fog light I could grab? I need to break the light to make my mounting setup work, and rather work with an already broken one if possible?
Oh, and I stuffed up and turned the car to 'ON' (without firing) with the AFM disconnected... so guess who has to remove the check engine light this week? >_<
Oh, and I stuffed up and turned the car to 'ON' (without firing) with the AFM disconnected... so guess who has to remove the check engine light this week? pinch.gif
Why do you have to remove the check light? Can't you just reset the ecu by disconnecting the battery?
Well I've seen the complicated procedure on here, but to be honest last time disconnecting the battery worked. Won't be too hard either way, plenty of threads on here.
Fair enough then, I thought it was either full reset, or just wait for the ECU to see the AFM enough time to reset itself.:blush:
Really?
If its going to reset itself i cbf playing with it!
Not a problem with the help....I've run out of things to do on my car and yours is the closest to me! :P
On other news I got my head pretty much around your HKS Kit....hopefully I will get a good nights sleep tonight now.
I have half a HKS turbo kit here, it looks like my V band setup has much better flow, how do they expect the wastegate gasses to flow through that u turn on the adapter mate?
I got my Brembos on, the caliper had about 10mm of clearance from the 17's. It looks great with the braided lines but these are a pain to bleed, I drove down some corrugated dirt roads to try and get all the air bubbles to the top and re-bled but they still feel spongy. Any ideas?
Got a bit done today; New Plugs fitted, new passengers side rocker cover gasket, and an oil & fiter change. A little oil in the rear plug recesses on the passengers side; but not too bad.
Also slipped some hardened washers under the Plenum bolts, as the Cap Heads had abraded the alloy a little.
Recieved my pack of 8mm rivet clips from Hong Kong and replaced a bunch of cracked trim clips.
Time to look at my Brake Upgrade again I think...
hey this sounds familiar....:whistling:
We bled mine twice right? Or was it 3 times?
I just drove em for a while and they firmed up...
Too familiar, the rears were fine but the fronts were re- kitted, as such they were empty. I think the pistons hold a little air around them perhaps? I didn't let the master cylinder empty at any point...
When I got my Stagea, the aftermarket front bumper was cracked badly and generally in poor condition. Over the weekend finally finished painting up a stock RS4 front bumper and slapped it on this evening. Didn't make it glossy enough, but still much better than the cracked bumper.
What a week full of brake upgrades!
Very happy with mine. What are you planning on doing Dale?
Edited by PN-Mad
fitted my 7 watt cree led reverse lights today.i cant belive how bright they are! on the box it says dont look at light within 1.5 meters what a load of shit......more like 5 meters!
Dude share the link. Me want!!!
you have to mod your lights at the back of them abit and also cut the plugs of and join the wires to the led itself but its very easy.i got them of ebay http://www.ebay.com.au/itm/160607562766?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
