I spent the whole day making my tracking unit close all the windows and sun roofs lock unlock doors remote shut down all via sms. Doing both sunroofs were a little pain in the ass to hook up but finally got it
It all works great now
Oh yeah made my auto lights turn off with the ignition only not the door because of the turbo timer
I am happy now
I am happy now
Excellent....can you drop by my car and do the same mods for me :D
Both those things shit me too. Especially the turbo timer which I will probably disconnect.
YES!
DO SHARE!
right now i got the lights turning off when the turbo timer turns off it works great but i want it to turn the lights off when i hit the alarm thats saturdays project
Koyo in, B&M Supercooler in, front BC BR's in.
Just need to bleed the cooling system now, get the rear coilovers in and give her a massive clean up.
Pics! :cheers:
With much trepidation I chopped several holes in my rear Aero bar to re- fit my towbar tongue...
Success! Had to cut a little larger than I wanted to to allow clearance for the bends in the bar but no scratches in the paint, so I'm a happy camper. Took a while, as I was trimming away small sections to sneak up on the final fit.
post-61153-0-35079200-1315189681_thumb.jpg post-61153-0-62118600-1315189772_thumb.jpg post-61153-0-66921000-1315189838_thumb.jpg
Edited by Daleo
You too Daleo, description is useless without pics... :whistling:
Fixed! :nyaanyaa:
The space at the top looks farking huge in the pics; but it reallly isn't that noticeable, and from a standing position; it's virtually impossible to see.
I wish they'd just made to tongue with one bend, instead of two; I just couldn't fit it through without a slot that big.:sleep:
post-18615-0-66490400-1315194341_thumb.jpgpost-18615-0-53311300-1315194392_thumb.jpgpost-18615-0-95696200-1315194437_thumb.jpg
Useless photos. We just moved house and I can't find our camera.
That and the grille is on it now and I couldn't be bothered taking it off. I'll take a better photo of the trans cooler when I change my grille. :whistling:
Things to note: The G35 Koyo Alloy radiator is about 20mm longer than the standard M35 unit, and the top and bottom tanks are approx 10mm wider. The airbox sits hard up against the fan shroud bolt, and the over the radiator cold air intake is not in a slightly different position. I'll likely shave some plastic from the airbox before long to try and get everything to fit nicely, but just an FYI - this isn't a perfect bolt in solution.
Given the additional length, the ends of the fan shroud need to be removed.
That said, the radiator itself does bolt on to everything perfectly. No custom mounts, AC condenser fits perfect and the standard rubber mounts go on it easy.
Can't figure out of it's waaay low on ATF fluid or ridiculously high on it. What came out of the hose last night seemed a lot darker than what I'm seeing on the dipstick. Since I filled the car via the dipstick "pipe" I'm guessing I just need to let it settle for a while before checking the levels. I imagine I'll have to add a fair bit of fluid given that it's probably dumped ~400ml in the swap, and I've added some extra hose and a whole trans cooler to the system.
yup same with putting a V35 standard radiator in an M35, well, the 3.5L one.
good work! looks nice in there.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
