took car to nissan service to sort out the ECL issue
if u guys remember, the codes that came out were 1110, 1111 and 1135
turned out there was an opened circuit at the intake camshaft on the passenger side, so after an hour's work to fix the wiring and $121 paid to nissan service, no more ECL coming up...happycheers.gif
the guy at nissan service asked me how i found out the codes without OBD2 scanner, i told him i talked to the ECU and it answered me lolwhistling.gif
lol just a short drive to the city this morning and i used a lot of fuel
nah its the same as a t30 xtrail - 22680-6N21A
thats for the hotwire only, not the whole tube - which isnt required anyway
Found a couple of links;
http://www.nissanpar...2680-6n211.html
http://www.cyberspac...n-uk/p1178.html
Slightly Cheaper price.
Edited by Daleo
Link doesn't seem to work?
Dunno what happened to that one, Google the updated part number (can't remember it, posting from phone) and it'll come up. Price was $190 aus.
Try this one :)
http://www.cyberspaceautoparts.com.au/contents/en-uk/p1178.html
Which Nissan dealer Syd?
it's the camberwell one cam, they were quite nice although they admitted my M35 was the 1st one they ever seen and with some luck they saw another one drove past on the same day lol
Cool, sounds like a reasonable dealership (Yes, the shock is overwhelming!!)
Went to Jb Hifi yesterday before work and was looking at getting a new cd player for my car but wanted to keep the HDTV i got in my car atm. So the guy there said i can keep my oem cd player in my rx and just get a FM extender to get all the fm stations in australia. Well this cost me $25 from autobarn so i was strapped. That was until i took my dash apart and seen that our aerial plugs are twin pin units and the fm extender is a single. So today i ordered the adapter from the UK for it. Cost me $75.00 AUD so all in all im still happy i get to keep the OEM unit. Just got to wait a little longer until the adapter arrives.
http://www.nexxia.co...ategory=Antenna Adaptors&section=Car Audio
I got my aerial adapter at auto barn for $10
Got the Cat back on, can actually hear the exhuast note over the induction sound. Gained a few ponies and must have lost 30kg's getting rid of that huge coffin mid muffler.
Front pipe is on next to go on when it arrives.
Edited by Ross
Fitted the new suction pipe toady with the help (should read totally lost without) Craig (aka Jetwreck, is there any thin on cars this man can not do).
This was certainly at the limit of my ability and patience to work on cars.
Thanks to Scott for hit great fabrication, only a slight mod of cutting a grove into the bottom bracket of the suction pipe so it could be placed over the shaft of the bolt.
For anyone looking to do this mod make sure you work with someone who is a contortionist as there is no bloody room to work in.
Net result is a good fit with a little bit of tidying up to be done on pipe work but the car feels even better down low in the rev range. Not had a chance to really test the top end as I am conscious that I need to finalise things under the bonnet and aware that I am currently running 17psi and want to be careful of hitting fuel cut.
thanks all.
Cheers
Andy
Had my mate in give the wagon a good cut and polish and wax job while I'm in renmark for the weekend. Looks very
Nice now. Just need to wash it again when I get
Home and give it another wax to finish it off.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
