With the 7psi actuator its hard to run any more than that, even with a controller. You may get 20psi midrange but it will always drop to around 15 by redline without increasing the spring tension on the wastegate.
The exhaust manifold pressure literally blows the wastegate puck open on boost bypassing the turbo hence welding a stiff spring to the actuator to hold it better.
All the stock turbo failures I have seen have been due to oil starvation/heat on the rear bearing as Dale mentioned.
Lol Scotty, I should have referenced you in there mate; it's been your hard work and development that has brought this information to light.
I fitted the dump by itself on a factory exhaust and I'm convinced it makes the turbos life easier.
Speaking of which, Slippy and I were both talking about running a dump on the standard exhaust.
Are there power gains to be seen from running an aftermarket dump on the factory exhaust? Would it be more hassle than it's worth running a custom system from the turbo back to the factory "sports" muffler? I know that the factory exhaust weighs a ton so I figure it's worthwhile getting rid of, but I quite like the fact that I can press a button and my exhaust goes quiet, but if it's going to significantly impact the gains it's just a waste of money trying to keep it..
Yes,, 100% worth the effort.
Standard dump has a cat in it. Which then connects to a mid pipe... with a cat in it... and the massive box of baffles.
If you really want to keep the Nismo rear I'd do dump and mid pipe. But you should see a huge gain just doing dump and midpipe.
Andrew at AM Performance designed his exhaust so that it matches up to the factory mounting locations, so you can buy a dump and midpipe and it should be easy to connect to the Nismo muffler. Or just get him to do it, either way.
This sounds good.
So would the midpipe replace the baffles? I want to get rid of that. Do you know if his system has a cat too? Think it would be a lot louder replacing the standard dump (cat), midpipe (cat) and box of baffles with just a cat?
This sounds good.
If you want it quiet, get a Blitz NUR cat-back and then get whomever to make up a dump and frontpipe/cat to bolt up to the Blitz.
Stock is 82dB
Blitz is 82dB (but 80mm and straight through design. Cheap too)
Everything else is 86db+
Stock is 82dB
Yeah see I'm fine with that every other day of the week, but the little switch is a nice thing to have. Especially while driving interstate to get rid of the drone.
Out of curiosity, what are the Blitz cat backs worth?
Thats what I like about the switch as well
I would be interested in your current system if you upgrade.
I got mine thru Jesse a while back & it cost ~$950. People have reported them for as low as $799 from Just Jap (plus freight?), depending on exchange rates & how many they bring in at a time.
Point to note, exhausts get louder over time as the sound deadening settles down. I'm very pleased I didn't go with a louder one as mine is now probably at the level that most guys would say is what they like, but if it keeps getting louder so help me..... lol.
Also, the tip is a bit on the big side for a 'mature' bloke like me.
Another late one trying to resolve the timing/electrical issue.
I'll attack this again tomorrow night....thanks iain for your help.
Edited by Jetwreck
no worries craig, see you there again tonight!
when we were bleeding the attesa system last night, craig put his foot on the brake and one of my braided brake lines split and pissed out brake fluid.
LUCKILY the old set were still next door. threw them on and im able to drive
just be aware M35 drivers, dont get the cheaper braided brake lines from IM. just get nismo or have a set made up by maltech. actually wasnt someone organising that?? im pretty sure i gave a set to someone to have that done
Front trim off and ECU out, to take down to SAS to see if they can chip it for tuning the Turbo Kit! banana.gif
Fingers Crossed!
Can you ask them for Craig and my ECU back that we gave them 18 months ago to see if they can tune our cars. :(
Faaark!blink.gif You surely dodged a bullet there Iain; could've been a disaster.
Specialised Brake & Clutch in Penrith made me a set of Goodridge ADR legal lines for my last car; they were around $80-$90 each. All pressure tested to ensure things like that don't happen.
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
