Drift seats installed.....
Helen & I got the stag washed today for the meet. The only part about washing the car I hate is after admiring how sweet it looks nice & clean. When you take a real close look all the stone chips & imperfections are visible. Oh well.....
Bit of an experiment, fitted a K&N pod filter to the stag today.
Needs some brackets to hold it in place but does the job, checking the Informeter readouts. Should also give me room for the catch can.
Tomorrow will fit the HDi Intercooler I got from Cam (Thanks mate - looks great!).
Finished up the install today for the iPhone connection via the AV input on the Commsman tuner. I used a little Narva push switch fitted in the coin storage inside the console to switch the tuner to the AV input.
Happy with the end result with everything tucked away out of view and neat and tidy when using it. The iPhone connect I bought doesn't support video on the iPhone but I only use it for music and I use the USB for movies, plus it was only around $30 delivered from the US. It does charge the iPhone so thats a plus.
Next on the list is a reverse camera once I decide which one to use.
Edited by slippylotion
Looks good. Should check out my reverse camera. Not installed yet, but it's wireless and replaces one of the number plate lights with the camera and an LED. Not quite the right size, needs an adapter made up as it's designed for a 350Z and is a bit too small.
I had a busy weekend, but still found some time for some Stag love.
First, I removed the airbox and test fitted a pod filter. The definite pro is that it makes plenty of room for a catch can, and flows more air. The con is that it now maxes out the injectors, and I need to check the intake temps. Not sure at this stage if it's worth keeping or not, but if I keep it I'll be replacing the temporary K&N filter with something non-oiled.
Today I started fitting the HDi intercooler. Underestimated how quickly it would get dark, and ended up trying to fit it in the dark. Not fun. Stopped for the night and will continue tomorrow, with the epic battle between myself and the standard hot-side intercooler hose :domokun:
New thermo fan doesn't exactly attach up as per the instructions either, but I'll play with it tomorrow in the light and work it out.
I just bought the similar camera but for the x-trail but not wireless. Looks easy to get to fit.
What resolution are our factory screens?
Depends which one. I think mine was 350Z/early X-trail? Just needs a surround to mount it up to the standard bolt holes.
Not sure on standard resolution, just know they're NTSC. Ask Brad or Leon, they'll know for sure.
Had a 70% (?) tune done on Saturday.
No a full tune as we had fuel failure, either filter or pump :(
On the plus side, no more "boost/fuel/air flow/whatever you wanna call it" cut and a different throttle feel.
Throttle is a bit soggier at the moment, but at least I know it can definitely be modified :whistling:
Edited by iamhe77
Is this the stock pump or aftermarket?
I think mine managed 248awkw on the stock pump...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
