Drift seats installed.....
Helen & I got the stag washed today for the meet. The only part about washing the car I hate is after admiring how sweet it looks nice & clean. When you take a real close look all the stone chips & imperfections are visible. Oh well.....
Bit of an experiment, fitted a K&N pod filter to the stag today.
Needs some brackets to hold it in place but does the job, checking the Informeter readouts. Should also give me room for the catch can.
Tomorrow will fit the HDi Intercooler I got from Cam (Thanks mate - looks great!).
Finished up the install today for the iPhone connection via the AV input on the Commsman tuner. I used a little Narva push switch fitted in the coin storage inside the console to switch the tuner to the AV input.
Happy with the end result with everything tucked away out of view and neat and tidy when using it. The iPhone connect I bought doesn't support video on the iPhone but I only use it for music and I use the USB for movies, plus it was only around $30 delivered from the US. It does charge the iPhone so thats a plus.
Next on the list is a reverse camera once I decide which one to use.
Edited by slippylotion
Looks good. Should check out my reverse camera. Not installed yet, but it's wireless and replaces one of the number plate lights with the camera and an LED. Not quite the right size, needs an adapter made up as it's designed for a 350Z and is a bit too small.
I had a busy weekend, but still found some time for some Stag love.
First, I removed the airbox and test fitted a pod filter. The definite pro is that it makes plenty of room for a catch can, and flows more air. The con is that it now maxes out the injectors, and I need to check the intake temps. Not sure at this stage if it's worth keeping or not, but if I keep it I'll be replacing the temporary K&N filter with something non-oiled.
Today I started fitting the HDi intercooler. Underestimated how quickly it would get dark, and ended up trying to fit it in the dark. Not fun. Stopped for the night and will continue tomorrow, with the epic battle between myself and the standard hot-side intercooler hose :domokun:
New thermo fan doesn't exactly attach up as per the instructions either, but I'll play with it tomorrow in the light and work it out.
I just bought the similar camera but for the x-trail but not wireless. Looks easy to get to fit.
What resolution are our factory screens?
Depends which one. I think mine was 350Z/early X-trail? Just needs a surround to mount it up to the standard bolt holes.
Not sure on standard resolution, just know they're NTSC. Ask Brad or Leon, they'll know for sure.
Had a 70% (?) tune done on Saturday.
No a full tune as we had fuel failure, either filter or pump :(
On the plus side, no more "boost/fuel/air flow/whatever you wanna call it" cut and a different throttle feel.
Throttle is a bit soggier at the moment, but at least I know it can definitely be modified :whistling:
Edited by iamhe77
Is this the stock pump or aftermarket?
I think mine managed 248awkw on the stock pump...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
