Drift seats installed.....
Helen & I got the stag washed today for the meet. The only part about washing the car I hate is after admiring how sweet it looks nice & clean. When you take a real close look all the stone chips & imperfections are visible. Oh well.....
Bit of an experiment, fitted a K&N pod filter to the stag today.
Needs some brackets to hold it in place but does the job, checking the Informeter readouts. Should also give me room for the catch can.
Tomorrow will fit the HDi Intercooler I got from Cam (Thanks mate - looks great!).
Finished up the install today for the iPhone connection via the AV input on the Commsman tuner. I used a little Narva push switch fitted in the coin storage inside the console to switch the tuner to the AV input.
Happy with the end result with everything tucked away out of view and neat and tidy when using it. The iPhone connect I bought doesn't support video on the iPhone but I only use it for music and I use the USB for movies, plus it was only around $30 delivered from the US. It does charge the iPhone so thats a plus.
Next on the list is a reverse camera once I decide which one to use.
Edited by slippylotion
Looks good. Should check out my reverse camera. Not installed yet, but it's wireless and replaces one of the number plate lights with the camera and an LED. Not quite the right size, needs an adapter made up as it's designed for a 350Z and is a bit too small.
I had a busy weekend, but still found some time for some Stag love.
First, I removed the airbox and test fitted a pod filter. The definite pro is that it makes plenty of room for a catch can, and flows more air. The con is that it now maxes out the injectors, and I need to check the intake temps. Not sure at this stage if it's worth keeping or not, but if I keep it I'll be replacing the temporary K&N filter with something non-oiled.
Today I started fitting the HDi intercooler. Underestimated how quickly it would get dark, and ended up trying to fit it in the dark. Not fun. Stopped for the night and will continue tomorrow, with the epic battle between myself and the standard hot-side intercooler hose :domokun:
New thermo fan doesn't exactly attach up as per the instructions either, but I'll play with it tomorrow in the light and work it out.
I just bought the similar camera but for the x-trail but not wireless. Looks easy to get to fit.
What resolution are our factory screens?
Depends which one. I think mine was 350Z/early X-trail? Just needs a surround to mount it up to the standard bolt holes.
Not sure on standard resolution, just know they're NTSC. Ask Brad or Leon, they'll know for sure.
Had a 70% (?) tune done on Saturday.
No a full tune as we had fuel failure, either filter or pump :(
On the plus side, no more "boost/fuel/air flow/whatever you wanna call it" cut and a different throttle feel.
Throttle is a bit soggier at the moment, but at least I know it can definitely be modified :whistling:
Edited by iamhe77
Is this the stock pump or aftermarket?
I think mine managed 248awkw on the stock pump...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
