Got the new 3.538 diffs in.....got some good umph now!!!!
My fears of the speedo being out are cured.....speedo and gps are exactly the same differences as they were before.
Care to explain how a change in diff ratio makes no diff (oh look, a pun) to the speedo reading? Am I missing something obvious?
Installed my new ECU this weekend.. NISMO Sportstune :banana:
Very first drive it is obvious the difference with the car being a lot more toey of the line. Best part to be experienced is in the mid range now coming on much stronger and faster.
Next step to put it on the Dyno and see what the AFR's are like and what the actual power out put is.
Is this enough power.. :whistling:
because (as i mentioned ages ago) the speed is taken from the ABS sensors on the OUTPUT of the rear diff. therefore no matter what ratio the diff is, assuming you dont change your rolling diameter, the speed will always be correct as the speed is measured after all the gearing.
where'd ya get that ratio, 34 gtr? I was thinking the same thing today.....
btw hills have a 4wd dyno. what computer?
Ratios are from then nm35 vq25dd or the pnm35....
....Hmmmm waiting for mark to give me a buzz back on the dyno.....to much longer and I'll be going to Victoria for a touch up!
Edited by Jetwreck
The Nismo ECU's.. how do they go with economy? Better/worse?
Emanage is a piggy back...so it needs an existing ECU to control.
The nismo ECU has certain "awesomeness" in it that makes the car a bit better to drive....and speed cut too I think
Craig's car has the Nismo + emange combo...
better.......you have an economy setting, it uses the snow button!
Worse......the drive is a lot more inviting so you tend to get up it a little more.
I think the main thing is no speed cut and no throttle restriction isn't it?
Has anyone with the Nismo snipped the brake wire?
Don't need to worry about that now though... :whistling:
I think he means with the fcon, the stock ecu still controls the throttle though. There are 4 wires extra in the loom plug I can't account for which may make some changes, not sure.
Doesn't explain how the throttle changed on my car.
Both much more responsive and also more soggy depending on map selected...
Without the infometer you are only guessing though. It could easily be tune related.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
