info is in the stagea section too but i'll chuck it up here as well
it was a protex - TE926-14
14 means 14mm tie rod, so just measure and if its 14mm ish then this is probably the one for you
they also have a grease nipple on them too, so should last well if they are greased up every so often
Had aluminium radiator and silicon hoses fitted last week. Looks great. Will take pic soon. Car heading to Sydney for Turbos, Injectors, power fc, fuel pump, cam gears fitted and tuned next Saturday :-)
The Mrs modified the front bar on a kerb this arvo. Nothing too bad. Did get a six pack outta it but!
If she comes home with a slab one day, I'll know shes done something bad!
Could this be your opportunity chop out the numberplate piece and a bit of plastic welding when repairing, or is it too far gone?
Fitted the Euro II today, now these are the seats it should have come with from the factory. :yes:
Lordy that looks comfy. A bit more sensible height than the std ones?
1319620594[/url]' post='6080672']
It's really fine, just a touch of the curb on the side. However I did use that as excuse to get the number plate and stone chips sorted out at a later date.
Scott that seat looks great. Much jealous.
Fine choice :yes:
Well that clears the pillar better than the other seat.
Very nice. Not putting one in for the Mrs?
Soon, has to be ordered with a 2-3 month wait.
Well worth the price it seems, they are very comfy seats.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
