info is in the stagea section too but i'll chuck it up here as well
it was a protex - TE926-14
14 means 14mm tie rod, so just measure and if its 14mm ish then this is probably the one for you
they also have a grease nipple on them too, so should last well if they are greased up every so often
Had aluminium radiator and silicon hoses fitted last week. Looks great. Will take pic soon. Car heading to Sydney for Turbos, Injectors, power fc, fuel pump, cam gears fitted and tuned next Saturday :-)
The Mrs modified the front bar on a kerb this arvo. Nothing too bad. Did get a six pack outta it but!
If she comes home with a slab one day, I'll know shes done something bad!
Could this be your opportunity chop out the numberplate piece and a bit of plastic welding when repairing, or is it too far gone?
Fitted the Euro II today, now these are the seats it should have come with from the factory. :yes:
Lordy that looks comfy. A bit more sensible height than the std ones?
1319620594[/url]' post='6080672']
It's really fine, just a touch of the curb on the side. However I did use that as excuse to get the number plate and stone chips sorted out at a later date.
Scott that seat looks great. Much jealous.
Fine choice :yes:
Well that clears the pillar better than the other seat.
Very nice. Not putting one in for the Mrs?
Soon, has to be ordered with a 2-3 month wait.
Well worth the price it seems, they are very comfy seats.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
