What Have You Done To Your Stagea Lately?
Hanso
Just installed the USA-spec pa15-nis. Very easy plug and play set up, only 3 plugs.
The sound is awesome as I expected. I can't recommend this enough to anyone (like me) that's wants to keep the factory single din stereo to keep it intergrated with the factory tv screen and wants to add in an iPod/iPhone to it. You can also add another audio device into the unit.
Music is all control either via the factory head unit or the iPod/iPhone itself and it charges them.
Only $160ish delivered via eBay out of the US.
Edited by slippylotion
I've been looking at foam lances for a while now for my Karcher; prices ranged from $200 odd blink.gif to just under $75 delivered (UK). These are pro quality items, and you can adjust how much foam you actually get.
Anyway, I saw this at Bunnings; http://www.karcher.com.au/aus/Products/Home__Garden/Accessories.htm?&sdp=ac&pid=26418480&accessoriesGroupName=Special+applications&pn=Foam+nozzle%2C+0.3+litre&title=Foam+nozzle%2C+0.3+litre&refP=%2Faus%2FProducts%2FHome__Garden%2FAccessories.htm%3F%26accGrNm%3D10011604__Special%2520applications
2641848_popup.jpg It has a 300mL cup and was only $15!
It works great! Took a little fine tuning to get the mix right; and you need to work fast in the foaming stage, (the cup empties fairly quickly) but now I'm foaming like a rabid monkey!banana.gif
For anyone who's wondering; the foam softens the muck on the paint better than just hosing; allowing you to pressure wash off most of the stuff that scratches the paint when you manually wash.
The more you can get off without touching the paint; the less fine scratches you put on the car. On a black car it makes a big difference to how often you need to do paint correction.
New front upper control arms with nolathane rubbers (or SuperPro????) for my NM35 today at Wholesale Suspension, Penrith, NSW.
This was on top of replacing the lower ones abt 6 weeks ago (by Jetwreck). The knock in the suspension had gone away but came back
again after a while, particularly when under heavy braking.
Picked the car up from Pedders, rear is dumped, but only just level with the front. Weird... but can't go any lower on the rear. Haven't measured yet though.
Got my new blow off valve in the mail today, Turbosmart Nissan specific dual port. Nicely made unit. Fit it this afternoon, not too hard, just had a higher pick up for the hose. Set it up as plumb back, and set it as stiff as it went.
Gives a fair bit of flutter, but other than that is all good. Will back off the stiffness in the morning and see if that lessens the flutter. Main thing is it fixes the 'farting', guess I'll find out over the weekend, with a drive to McLaren Vale and back.
Picked up my car from All Type today. Largely happy with the job, would have liked them to touch up the car more, but I think I always knew that the job wouldn't be up to my standards..
Grille is painted and fitted. Wing will go on tomorrow when I get some adhesive rubber stuff for it.
yep, that is indeed a good start. too small but at least it gives an idea of how they would look.
actually that looks like a well built car at a glance
Lol, I was only really referring to the exterior; rivetted on flares over the existing rear doors, etc.
Everything under the skin is beautifully fabricated.:thumbsup: Definitely has attitude.
    • You won't make it out of your driveway. Both your rear wheels will go in whichever direction they feel. Your Hicas rack or a lockout bar is required to keep your wheels straight.
    • Updating results.  Using ATR45SS-0 model VS UHF57-900. Those two are very different turbos, different wheels sets with different wheel hub profiles but yet with almost identical result. I’m intrigued with both turbos performance. ATR45SS-0 was a 61mm turbo first developed in May 2020, UHF57-900 was a 62mm turbo developed in March 2024 as a powered up alternative of a G30-900. On paper ATR45SS-0 maxed at 563rwkws, while UHF57-900 maxed at 568rwkws. ATR45SS was slightly more responsive with slightly better power band through the mid range.  Road driving ability, ATR45SS-0 had better throttle response, felt more robust under throttle, as it wakes up earlier. I think G series wheel hub design made it to have higher inertia under light throttle. Doing bit more prototype work in the next few weeks, will update result when its back on dyno again. ATR45SS0 Blue, UHF57-900 Red Chequered tuner's Dynapack hub dyno, E85 fuel. Mod list is in video below video_20240604_114214.mp4
    • Did you run the power cables for the mac valve to the other side of the car near the fusebox? Utilizing the stock boost controller cables? or did you run new ones?
    • Hey I have a potentially stupid HICAS question 🤣 I'm currently doing a full hicas delete, Power steering pump modified to non hicas, all lines removed from the car along with all electronics. My stupid question is - Do I need a lock out bar? is there any reason why I cant just remove everything from the rear end? I already have a lock out bar but thinking to save a few extra grams I could also get rid of the arms and tie rods as well and just run it with nothing in its place? or would it have a negative effect on handling?
    • Hi how are you guys?  I know i have been absent for years but im coming back slowly guys just wondering if anyone know where the ball joint on the NISMO arm front and rear can be replaced with OE parts?  Also  i know this is not the thread looking for springs and blistein shocks for the 260rs. Please advcie     cheers    yudy
