Dropped car off at dart automotive on Saturday morning. Turbos, i dump pipes, fuel pump, injectors and cam gears have been fitted today. Power fc gets fitted and tuned tomorrow and pick car up tomorrow afternoon. Looking forward to seeing the results
It is certainly better than on the stock pump but at redline I am getting up to 95% duty cycle but this is with AFR of 10.5 so not too worried about that.
I agree, nothing to worry about. Rich AFR & still duty cycle to spare so headroom for more performance. Nice one.
called bearepairs
basically as follows:
him:"we don't touch the tierode ends to do an alignment"
me: "but you said you inspected everything under it"
"oh yeah, wanna bring it in and check it all again"
"yeah"
(slightly summarised)
fingers crossed they don't jew it up this time, heading up to the boat this arvo
so keep an eye out of me between melbourne and the gold coast
Took the car to Nizfest on the weekend - a club day at Hampton Downs - Z club, Primera club and my club: Skylines Downunder - which has a Stagea section. Didn't take part in the show and shine or Gymkhana but had a track session. The new RB30 setup is not fully sorted yet (will post up details and charts when it is) but still fast enough to beat some of the GTRs (R33 and 34 that is, not the new GTRs) but eventually ended in a cloud of smoke. Will be engine out job to fix some oil control issues (smaller restrictors, head drain, sump breather). But getting there slowly!
yeah queensland is the same, and quite obviously we pay a premium for them
Yeah it's weird.
Up to 5 letters, and minimum 1 number, and you pay a once off fee, around $70 last time I did it.
6-7 letters is a different class, and you have to pay per year. Used to be $300-400 per year.
colour went down on car today just pearl over top tommorrow, also got my new plates for when she is all done:
Loving the 2 tone and the blue stripe; can't wait to see it with clear on. Very nice work.:thumbsup:
just casually drove from melbourne to the gold coast in 2 days
best fuel consumption (off bp ultimate funnily enough) was a staggering 9.63562753 l/100km
Started fitting the Transgo shift kit to the M35 today.
While the car was on the hoist I noticed the drivers side front drive shaft has split the inner boot. How much are people paying for the new boot and is it a DIY job to fit the boot?
Yep on my mates hoist. Shift kit is all fitted, just ran out of time so will refit the valve body tomorrow and test drive.
So not too bad a job then? Got to do mine soon.
All going to plan so far, just take your time and double check everything. It was good having a mate check every step with me. If you have GOOD mechanical skills it shouldn't be a problem to do yourself.
I paid $125 to get a work shop to do mine in Sydney.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
