Is it true you need 19 inch rims to clear these? Been looking at these for a while.... very jealous :)
:yes:
:no:
ADM 370zs have 18" wheels over the brakes. So no, you don't have to run 19s.
I do think you'll have to try hard to get a wheel with offset/ spoke clearance to fit them though, and thats when 19's give you that little bit of advantage.
:no:
Damm, that could be the deciding factor for me not getting a bigger set. I think the 355mm Akebono BBK is excellent value, but slim chance of those fitting. May have to print the template one day to double check exactly what will fit.
:no:
I thought that they had the Akebono 'Sport option" like the 350z did with the Brembo upgrade... with 18's, non Akebono but they get 19's if you select the Akebono option
Hmmm.... would appear that they were standard an all 370z's over here. Oh well, there ya go. Get a set of 370z rims Leon... have seen them advertised under $1k on other forums
Edited by iamhe77
Yes they are a great value BBK. Just be aware that the stock rotors are bloody heavy. I dunno if PMu stuff is lighter but you would have to sell your kidney to obtain PMu rotors I'm guessing ($$$) . I think there has been some 2 piece rotors brought to market by someone to try to lighten the kit up a bit- but the source evades me ATM.
I think the sizes are teh ghey. Their staggered for a start, and I think the fronts run a really high offset? like +47 or something?
Nice placement Leon, that's where I was hoping to fit the wideband. Have you got some better close up pics?
Ask & you shall receive. PM sent.
Stoptech
Thanks mate, much appreciated.
Stoptech
I think DBA do a 5000 series T3 multi piece rotor for 370Zs - worth looking into.
nah caltex eflex. when ramped up it did crack 300 but it averaged it to 297-298 cant remember scott will be getting the graphs, just hypergear turbo full exhaust n dump and intake (made by scott) and 1000cc injectors n emanage ultimate, we drove it up there untuned on scotts old map and it drove it a standard car, still does very nice to drive
fitted a new cooling pro return flow cooler nd jjr front and dump pipe to my car last week. not exactly direct fit for the Auto's, but managed to get it squeezed in without cutting front reo bar (twisted lower part slightly) nd front and dump pipe slightly short so from cat back all had to be moved forward nd trans bracket removed.
got car booked in for shift kit on tuesday. nd then got it going on for a dyno run at the SAU dyno day then get it tuned after that some time as i need to start saving money for trip
Nice work - good numbers! But how the hell did you get Hypergear to do your turbo so quickly? Mine took nearly a month to get back to me & I know when Scotty dropped yours off..... Must be who you know I suppose :)
Did you get the engine cover on and hide the Emanage away yet? It should look as stock as it came in. :)
I guess it helps that I dropped it off and had him under the pump to pick it up. The Easter holidays wouldn't have helped either. I'm fairly sure he outsources his machining work so time can blow out as you know. Is it on yet? What wheels did you end up with?
scotty engine cover is back on ur intake pipes r black so is the drivers side cooler pipe, emanage is hidden and painted the cooler black today nice and stealth :P been driving it alot today the mrs drove it she loves it, i launched it today hard..... well yeh u can guess how that went hahaha
Brief run down of the mods that obtained the above?
Auto Box messed with?
Shift kit
Full 3 inch exhaust with custom dump/front pipe
Hypergear highflow
HDI cooler
3 inch intake
Xspurt Bosch 1000cc injectors with plug in adapter
Emanage ultimate
300lph Deatschworks fuel pump @ 14v
Looks completely stock and legal with the engine cover back on.
So the speed limiter isn't defeated? And what's with the boost control, Thought it'd be flatter than that?
I have given Marko my SLD, as long as the Fcon gets rid of speed cut...
Boost curve isn't too bad, I like the power curve, its like a V8. (Stao didn't open up the wastegate so it spikes to around 21psi or so.) We could have bumped up the midrange a little to flatten it off but it drives great either way.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
