I wouldn't bother mate. If you are dead serious about power, then get a different (3inch) muffler welded on the end and keep that Muffler. But I would suggest if you don't have a high flow turbo, piggyback, etc etc, I don't think the exhaust will be that big a deal. I'm only going by the Mods in your Sig. Do you really want it louder? Doesn't seem like it has any muffler to it anyway!
Fitted Tein S-Tech springs in my series 2 RS4S yesterday. Was hoping for the 1.5inch drop that they claim but it's only dropped about 10mm in the front and practically nothing in the rear. Just hoping it'll settle down a bit over the next couple of weeks with driving. It's definitely stiffer though.
Went to drive it for the first time in 2-3 weeks, found the battery was flat.
Put it on charge for about 6 hours, checked voltage, 1.5v. Pulling it out and putting it on a deep charge for a couple of days to see if it'll be ok, since it's only about 6-9 months old. :(
just fitted a new rack end on passenger side, bought a new pair from ebay (link from Dale)
http://www.ebay.com....#ht_1749wt_1037
after fitting it and drove the car, steering was very loose that when i came out to check the wheels. the left one (passenger side) had a toe in about 5-7 degrees :angry:
after a closer inspection, the new rack end is actually longer than stock one (refer pic) so had to cut off to roughly the same length, now just need to do wheel alignment
thought to share this so if anyone else needs to change the rack end to the same ones i bought, better measure and cut 1st
I had to remove those two black strips at the edges of the tailgate lid & the spolier screws into the metal beneath where they sat.
Then it just basically sits on top of the black plastic trim that the centre brake light is part of (with help from a bit of double sided tape)
I'll take some more pics when my wife gets back from the shops with it. :whistling:
Dyno'd the car last night. Car feels awesome to drive. Less boost made more power.....18.5psi ftw!
240killa wasps....car feels strong right through the range.
Jez the tune is awesome....and the f$@ker starts hot or cold for the first time in a long time.
Excellent buddy :) glad ur happy.
Sorry about the dyno sheet. Damn dyno restarting on me. Forgot to input ur details back in correctly.
Haha i underestimated ur car. Wheelspin on the 1st pull of the night. Was exciting. We need to find a way to lock it into gear though. Was hard to tune below 4000rpm. Will have a play on the road when u are ready
Limp mate, the kickdown is just to keep you on your toes. :P
The torque converter lockup solenoid needs a 12v voltage on it for a start...
I made up some speaker mounts for the M35 to fit some Alpine Type R 6.5" front splits and 6.5" rear 2 way coaxial speakers. Made them out of some structural ply I had laying around. These will finish up with the speaker sitting close up to the door trim as the factory speakers do. Will finish them up and install them over the next few days. Pretty happy with the result so far.
Edited by slippylotion
Haha sure did. Foot flat 100rpm too early and it
Jumps down a gear.
With the lock up how well does this work? It would be good to do this just whilst tuning then we can put back to standard
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
