yeh it was raining. lol i went home and slept. reason as to why im up now. ill swing past after work tomorrow pending pickles...
honestly i wouldnt port it.. wouldnt want the same problem that ended up happening with Vartis' head. f**k that
looking good scotty, how long til your done i want to take a ride in the great white whale :yes:
on another note i made my car SLOWER!...............with a set of Grex Alcon callipers and discs!! ;)
Installed the apex-i cat back I got from ross... Not really happy how it sits. I feel it could stick out about 2-3 more inches but it will do for now. Ill adjust it when I get the rest of my exhaust done.
Fitted front & rear Whiteline swaybars & rear links today (thanks Dale!) - will fit my new SPC rear camber & toe bolts next week & Superpro front camber & caster bushes as soon as they arrive (thanks again Dale!!!)
Car sits about one mullion times flatter with the new bars & would happily crack it sideways around sharp corners under a bootfull of power if it wasn't for the lack of LSD.
Highly recommended mod in the unlikely event you haven't already heard about it.
they look good dale!
Hopefully they'll look even better once they've been coated. :thumbsup: Getting a coat of deep black, and then a coat of 600deg clear to finish off.
Do the GT-T calipers bolt up to the standard hubs w/ standard discs?
They bolt straight up to our hubs with the added bonus of M14 mounting bolts (as opposed to 12mm on R32 GTR & R33 GTSt).
You need the matching 310mm x 30mm GTt rotors.
Looks like it's worth the effort then Dale! Easy solution (if, of course, you don't strip and rebuild/repaint!)
Was less pissing about than I was expecting actually; I had less trouble getting the pistons out of these than any caliper I've ever done.
I chucked them on really quickly in the workshop today, to see what they look like; I'm dying to get them finished now!
Pics once they're done.
OK, so after I bought the new front bar I did a trial fit of it to see how it sits compaired to the old one.
BEFORE:
AFTER: DSC01571.jpg
I'm also in the process of making up some blanking plates for the LED indicators supplied with it. Below is a pic of the LHS blanking plate partially completed.
FRONT VIEW:
Below is the template + LED lights
Why not just incorporate it into the stereo?
Ian, new front bumper looks heaps better!
Huh? It is incorporated into the stereo...it uses the factory head unit and speakers.
If your asking why I didn't buy a BT enabled headunit instead... I don't want to spend hundreds of dollars in parts just so I can fit a single/double DIN unit that won't do what my phone and a $99 WDTV can do. Know any headunits that can support NTFS? I'm sick of being limited to USB sticks for storage.
How does it connect to a head unit for music playback, Is it RCA or via the radio?
It can play back music via BT A2P streaming - the unit connects to the factory system via RCA. I didn't enable it since the AUX in will be used by a WDTV unit.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
