Very happy mate. :yes: Bring your laptop next weekend please? I think I'd like to try that last degree.
Any time mate; happy to help out. Drilling holes in other peoples stuff, while partially drunk is my speciality...
What!!!!!!
I have taught you well! ;)
Ian, new front bumper looks heaps better!
Thanks Ryan.
I'm in the process of making the blanking plates to fit the LED indicators. I've posted the progress so far in the Fabrication section.
link is here => http://www.skylinesaustralia.com/forums/topic/402693-indicator-blanking-plates-for-aftermarket-front-bar/
Lol. Yes, yes it is.
Try failing to get the thermostat on correctly, filling it with coolant only to have it pour out all over the floor. Then pulling it all apart again to fix. Derp. Amateur hour.
How did you go with the trimming?
ohh yeah the radiator. damn its big, if you overheat with that ill be surprised!
Yep; she's big bugger!
Yes it is.....funny though! Trim....then trim....then trim......ect.
Thank goodness it's not metal though! ;)
Fortunately, I had a hoist, die grinder and air hacksaw in my arsenal today; needed all of them. :yes:
I'm not completely finished, I'll be making a new set of top mounts; doesn't fit the OEM top positions. Bottom end was nice once I'd done some trimming.
Drift Spec cable tie top mounts ATM. :whistling:
Also sent my R34 rotors out for slotting today, and had my current front rotors skimmed as I've recently picked up a bit of a shudder. My new set up looks like being ready to go on in a week or so.
Edited by Daleo
I bought Iain's China Rad, that was then modified to be a bit more of a direct fit. The trans cooler loop & fittings were nice too.
Which it was, but yeah it was a bit of an ordeal.
A little bit more neatening up, and I'll be happy. Just got to push the airbox lid in a bit with a heat gun and I'll be sweet.
Possibly one more bleed/top up, but I think I've got it sussed now.
Yes, they are. You can nail it in one go, but sometimes it will take you a good few trys. Nothing overly hard about it- open heater core, use the rear bleed, but sometimes it is just easier than others
Nice. I haven't looked into it yet, are these things a pain in the neck to bleed the cooling system too?
Not really, but I used a little tube & a funnel to get a bit of extra head height to get the air out of the rear bleed point once I'd filled the cooling system.
I waited for it to cool off again tonight, then topped up the rear bleed point and got a bit more air out (put about 250ml more water in).
I'll check again tomorrow morning, but I think it will be ok.
Lol, err, maybe it is then...
Still no pinging either. ;)
Edited by Daleo
Sometimes a pain, sometimes not was what I was getting at. I bled mine for a good 20 mins or so, using exactly that method you described Dale. Parked it up, the next couple of times the car was allowed to fully cool off, the bugger drank all the overflow tank. So, I cracked it again and worked on it some more, and its good now.
Never gets hot - plus I have the fans set to 88 :)
Yeah spot on, mine was all good this morning, and I'll check it again tonight.
Mine is now steady at around 86 deg, when going slow or stopped; it might get to 89. Big difference to 88-94 deg running and a max of 104.
We'll see what it's like when we get some hot weather, but the core was more than twice as thick, so it should be fine.
I got the white whale started today, the timing chain rattled like crazy for at least 5 minutes until the tensioners pumped up. All good, no leaks and the coolant stopped bubbling after a short while. (unlike before. lol.)
Here are some pics of the coolers, both sides have thermo fans behind them, a 14 inch for the 12an oil cooler and a 9 inch for the trans cooler. I also have a controller to switch them both on at whatever oil temp I decide to set it to.
I scored this wood heater for the shed too, it makes this Melbourne winter bearable now in the man cave. :)
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
