Very happy mate. :yes: Bring your laptop next weekend please? I think I'd like to try that last degree.
Any time mate; happy to help out. Drilling holes in other peoples stuff, while partially drunk is my speciality...
What!!!!!!
I have taught you well! ;)
Ian, new front bumper looks heaps better!
Thanks Ryan.
I'm in the process of making the blanking plates to fit the LED indicators. I've posted the progress so far in the Fabrication section.
link is here => http://www.skylinesaustralia.com/forums/topic/402693-indicator-blanking-plates-for-aftermarket-front-bar/
Lol. Yes, yes it is.
Try failing to get the thermostat on correctly, filling it with coolant only to have it pour out all over the floor. Then pulling it all apart again to fix. Derp. Amateur hour.
How did you go with the trimming?
ohh yeah the radiator. damn its big, if you overheat with that ill be surprised!
Yep; she's big bugger!
Yes it is.....funny though! Trim....then trim....then trim......ect.
Thank goodness it's not metal though! ;)
Fortunately, I had a hoist, die grinder and air hacksaw in my arsenal today; needed all of them. :yes:
I'm not completely finished, I'll be making a new set of top mounts; doesn't fit the OEM top positions. Bottom end was nice once I'd done some trimming.
Drift Spec cable tie top mounts ATM. :whistling:
Also sent my R34 rotors out for slotting today, and had my current front rotors skimmed as I've recently picked up a bit of a shudder. My new set up looks like being ready to go on in a week or so.
Edited by Daleo
I bought Iain's China Rad, that was then modified to be a bit more of a direct fit. The trans cooler loop & fittings were nice too.
Which it was, but yeah it was a bit of an ordeal.
A little bit more neatening up, and I'll be happy. Just got to push the airbox lid in a bit with a heat gun and I'll be sweet.
Possibly one more bleed/top up, but I think I've got it sussed now.
Yes, they are. You can nail it in one go, but sometimes it will take you a good few trys. Nothing overly hard about it- open heater core, use the rear bleed, but sometimes it is just easier than others
Nice. I haven't looked into it yet, are these things a pain in the neck to bleed the cooling system too?
Not really, but I used a little tube & a funnel to get a bit of extra head height to get the air out of the rear bleed point once I'd filled the cooling system.
I waited for it to cool off again tonight, then topped up the rear bleed point and got a bit more air out (put about 250ml more water in).
I'll check again tomorrow morning, but I think it will be ok.
Lol, err, maybe it is then...
Still no pinging either. ;)
Edited by Daleo
Sometimes a pain, sometimes not was what I was getting at. I bled mine for a good 20 mins or so, using exactly that method you described Dale. Parked it up, the next couple of times the car was allowed to fully cool off, the bugger drank all the overflow tank. So, I cracked it again and worked on it some more, and its good now.
Never gets hot - plus I have the fans set to 88 :)
Yeah spot on, mine was all good this morning, and I'll check it again tonight.
Mine is now steady at around 86 deg, when going slow or stopped; it might get to 89. Big difference to 88-94 deg running and a max of 104.
We'll see what it's like when we get some hot weather, but the core was more than twice as thick, so it should be fine.
I got the white whale started today, the timing chain rattled like crazy for at least 5 minutes until the tensioners pumped up. All good, no leaks and the coolant stopped bubbling after a short while. (unlike before. lol.)
Here are some pics of the coolers, both sides have thermo fans behind them, a 14 inch for the 12an oil cooler and a 9 inch for the trans cooler. I also have a controller to switch them both on at whatever oil temp I decide to set it to.
I scored this wood heater for the shed too, it makes this Melbourne winter bearable now in the man cave. :)
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
