good to hear scotty!!! please tell me your putting the standard engine cover back on :P
Yep, its all back on, looks stock other than the fuel reg and gauge hanging at the side. :)
Nice....enough coolers.
I think so, lol. I haven't hooked the controller up yet but I don't think I will need the thermo's in winter anyway.
I ran a Greddy cooler through the bandsaw, the core ended up around 220mm high from 300. I then bolted the end tanks to the intrusion bar. This is the same cooler I have been running for a while.
The lobster pipe is welded to the cooler as the bend was too sharp to use a silicone 90, plus my cooler sits very low compared to the HDI.
The hot side is all replaced up to the turbo, 2.5 inch stainless and a 60mm alloy bend into the cooler.
And You call me a butcher.. Mr bandsaw
Can you suggest another 600x220 core I can use? lol.
It cost me $100, I wasn't too worried. :P
It's obviously not a restriction to power either. :whistling:
A third of the HDI core sits right behind the bumper Reo; getting almost no airflow anyway.
Exactly, and inside the top of the cooler (the part I cut off) isn't going to get much airflow as the compressed air is travelling too fast to bend up there.
Yep, I've actually seen people weld small air diverters into the end tanks; which direct air into the top & bottom of larger intercoolers.
Doesn't increase pressure drop, and increases cooler efficiency as you are using the full area to cool; rather than just filling up unused core area with pressurised air which is basically static.
Needs more N1 vents :ph34r:
Even with the vents; you've still got an amount of core that's basically blocked, but the vents and some decent holes in the reo would help. Doesn't do much for the integrity of the Reo; nor it's legality though.
With a smaller core; you'd have the opportunity to do as Scotty has done, and move the core forward, giving more room for trans/oil cooler cores & fans. You end up with very little spare real estate with the HDI core in place.
Just wondering if anyone has thought of a low, wide scoop attached to the top of the reo to direct air down through the top of the HDi cooler.
Wouldn't be difficult and wouldn't have to direct much air either.
Was just thinking maybe 5-10mm x 300mm of the air that passes through the lower part of the grill diverted behind the reo towards the top section of the cooler...
I'd suggest some actual testing of how much air flow is resticted by the REO is necessary before that gets done. I wouldnt have thought it'd be too difficult to put something in place to measure the airflow at the bottom and then move it to the top (behind the REO but 'on' the core), possibly even behind the core to see how much flows through it (because thats the important bit, right?) ?
You're referring to a wider version of the OEM intercooler scoop right?
The cooler sits so close to the back of the reo I'm not sure how effective it would be.
Wouldn't be difficult to make though. It would all depend on the positioning of any ancillary coolers that are fitted in that area.
Its been so long since I have seen mine, but I agree that would improve things. I think you would only be pressurising the space, not flowing much extra air through it. Plus the radiator needs clean air too.
A question to those with M35's, Have you left the under body plastic beneath the engine or removed it?
Any problems with removing it indefinetly? i find it such a pain to remove any time i want to have a poke around down there.
Edited by Ross
I have left it Ross. No problems removing it, but cooling may suffer, as you want to duct as much air as possible through the radiator, and not bouncing off. Also sticks, rocks, and other grime may well get up there. I really don't want a rock going up into some of the stuff I got in there.
Left it in. Would only remove it if I replaced it with a custom item that allowed oil changes without removing the whole damn thing.
That being said, everything should have a look for leaks/damage/etc at when servicing anyway...
Changed my fuel filter. That was fun times.... Re-leveled my ATF, because I thought I had over filled it a little, and Re-installed my chassis brace without spacers.
Going to leave cleaning it till tomorrow for the Stagea Meet! Needs a good scrub.
Mine didn't come with the larger plastic panel (so oil changes are very easy) & haven't noticed any issues but would probably leave it if I had the option.
There is another smaller plastic cover further back that you will want to leave on. I removed mine & got a vibration at freeway speeds - felt like a tyre out of balance. With cover back on the vibration was gone, so there must be some aero benefit in having it there.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
