Last week installed and uninstalled apexi zorst. friday I also installed dales underchasdis front brace. Very satisfied with the result.
Looking good! ;)
BTW R33huntme; that's a mean looking nose mate! Side on pics please?
Edited by Daleo
Somehow broke my PWR radiator: leaking after 18 months, only having travelled around 4000km, using only correct coolant. Sucks.
On the plus side, just ordered a GReddy suction kit and Z32 afms...
Unless you know where to get cheap PWRs from....that would be worth fixing.
Not very exciting but replaced the rear gearbox mount (auto)... It has made so much difference! I have been putting up with vibration under load that always got worse in the cold and wet weather. I have been troubleshooting this vibration for ages and was thinking it was the gearbox, front shaft, tyres!
15 minute fix if you have a hoist, was a bit suprised it was worn as my car only has 130,000kms.
Part Number 1132001U01 for anybody that is interested.
Adrian.
done an oil and filter change today the part that sucked was having to jack the entire car up and put in on bricks just to get under the thing LOL
Should have left it outside mate - they do that for you in the Riff
:P
:P
Lol, you've only got to drop below 60km/h.
Wheels gone, on bricks, and your dog has an uncomfortable look on his face....
Bought mine a 20lt drum of Syn X6000 today.
Edited by Daleo
How much was the 20ltr drum? Im due for an oil change.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
