Update: they're now claiming that incorrect coolant has caused both buildup in the radiator , and they don't cover warranty for corrosion...?!
Last time I checked, corrosion caused the opposite effect to buildup. Coolants used have been as per their rocommendation since the beginning.
They claimed that straight water came out of the radiator when they received, which we politely explained was due to me having to refill it to limp the car 8km to my mech after the car was towed home from the last Stagea cruise.
It's getting pretty frustrating now, but I'm adamant that we have done nothing wrong. The real pain is not having the beast on the road during the coldest part of the year!
Will update when things progress...
Wrong Coolant eh? What a coincidence...
checked all fluids n gonna give it a revtune tonight to get it read to run the 1/4 mile tomorrow
Good luck with that. I hope you get a good time. Nay, I'm expecting you to get a good time (for a M35 anyways).
I too wish you luck!
I'm going to take a punt. 13.2 at 114mph.
That's my guess.
Good luck buddy, still a few teething problems with mine, I'm not sure I want to hit 200kph on the new disks/pads, that and I had a couple of cooler clamps let go today. I will try to have it ready for the next one. :)
had 4 runs all of em shit haha. first run couldnt stall it up and get it on boost (same problem as every other run) and ran a 12.9 @106 which i was happy with first shot, every other run i missed a gear change or couldnt get it on boost so just went home. stalled it up on my street and it cam on straight away haha oh well
We did 2x Cooling mod (yes Scott, heaps of pics for ya) and 1x plenum spacer today... hub bolts, spacers and wheels tonight or tomorrow
Plenum + spacer
Cooling Mod
Also meshed in that little opening in the timing chain cover
Why? Well this is what we found between the heads (under the runners) in a V35
Seems it can make for a nice warm little home for mice :/
Mate, enough with the excuses, lol. There's no need - that's a great time regardless. Good job :cheers:
Today I pulled the passenger side valve cover off. Getting pretty quick at removing the plenum, associated plumbing & wiring (it's my 3rd time afterall :( )
This time there's no sign of oil leaking past the gasket so I must have got it right last time. Afaik that only leaves the banjo oil line on top of the turbo as the culprit. Looks like the turbo's gotta come out again, & that's gonna take a lot longer :/
Sniff...makes me sad.
Edited by Commsman
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
